Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-16-2022, 07:53 PM   #15
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
NP. Please report back here after you bring it in to let us know if that fixed it.
Will do!
vindiesel is offline   Reply With Quote
The Following User Says Thank You to vindiesel For This Useful Post:
x808drifter (11-17-2022)
Old 11-17-2022, 03:21 PM   #16
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by vindiesel View Post
The dealer programmed the baseline. I haven’t reset anything I was under the impression tpms sensors have a predetermined psi set point that cannot be adjusted and or curious if other people had issues or what their set point is for low psi warning.
I believe you can reprogram the baseline by setting the pressure to whatever you want and then following the "initialize TPMS" procedure described in the owner's manual:
  1. Turn ignition off
  2. Set tire pressure to 35 psi (pump/bleed)
  3. Turn ignition on
  4. Press and hold the TPMS button until the "low tire pressure" light blinks slowly 3 times
After I did this, I only saw low tire pressure warning when my tire pressures go below 28, and they frequently are at 28 at the start of my track day sessions.
Follow the build thread for my GR86!
timurrrr is offline   Reply With Quote
The Following 3 Users Say Thank You to timurrrr For This Useful Post:
Aroundomaha (11-25-2022), Desertnate (11-18-2022), H380 (11-18-2022)
Old 11-26-2022, 01:28 PM   #17
vindiesel
vindiesel's Avatar
Went to dealer for oil change and had them look at tpms sensors. Well since a master tech wasn’t there and they tried resetting them and overwriting software they are still not communicating to each other or the module. So I’m getting a loaner vehicle during a week while the master tech is there and they already made a claim with Subaru.
x808drifter (11-27-2022)
Old 12-07-2022, 12:19 PM   #18
vindiesel
vindiesel's Avatar
Update: 12-7-22
The dealership had my car for 2 days total and they said they put a few new tpms sensors in, checked all the wiring/electrical and the control module itself needs replaced due to not communicating with tpms properly. Mind you all my tpms sensors were accurate and working before I took it there to have them see why I got a low pressure light at 34psi which according to people on here is not right. Im guessing when they tried to reprogram/reset it from the initial factory programming it failed.
So they told me to pick it up today (im guessing I have no pressure tire readings and if I get a flat or destroy my wheels thats on them due to a warranty claim) The part is on back order
Old 12-09-2022, 03:31 PM   #19
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Have you or the dealer tried to follow what I suggested a couple of posts above?
Old 12-09-2022, 08:35 PM   #20
X25
Sr. Spiritual Advisor
X25's Avatar
Drives: 2023 BRZ Premium
Does that work for pressures below 28? My cold starting pressures are usually around 25/26 PSI, and this method did not seem to work right for me. I saw the 3 blinks, and it seemed to work for that session. But next time, it was complaining again until tire pressures hit >30 PSI.
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4
'21 Tesla Y Long Range AWD
'19 Corvette Z06 Z07 (Track Build Thread)
X25 is offline   Reply With Quote
Old 12-09-2022, 09:35 PM   #21
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I don't know.
I can imagine that "<28 bad " is simply hardcoded in the ECU.
Old 12-11-2022, 07:18 PM   #22
vindiesel
vindiesel's Avatar
I would ignorantly assume they should know that procedure. They got Subaru America involved and expediting the control module.
I personally have not tried that.
Old 02-10-2023, 08:33 PM   #23
vindiesel
vindiesel's Avatar
Well just got my car back. After waiting for a month for the part to come in it is finally fixed. They replaced the tpms module and it functions fine. Well I haven’t drove it enough to see where my low tire pressure is at now. But all good.
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
The Following 2 Users Say Thank You to vindiesel For This Useful Post:
timurrrr (02-13-2023), x808drifter (02-12-2023)
Broke a TPMS sensor, process with ATEQ Quickset and new TPMS Sensor? Anthonyc77 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-19-2018 09:57 PM
FS- TPMS System for cars without TPMS- New solort Wheels and Tires 1 03-17-2017 12:12 AM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 09:11 AM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 09:25 AM
