#15 |
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
Do you have a sway bar as well? I've just sourced sway bars, and will try their original recommended settings again, this time with 22mm Perrin sway bar at its soft setting (which is very close to what they asked for in recommend setup instructions).
After a lot of testing with that setup, I'll also test out a complementary 19mm rear bar. We'll see how it all works out
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) |
#16 | |
Drives: 2022 BRZ
Not sure who that was addressed to. If it was me, yes. I set it to 2/2 (max stiffness is 4/4). Front end response was too delayed at 1/1. |
#17 |
Yep, it was to you. I'm guessing it's Karcepts bar with that many settings? My baseline setup recommends 2/3 with that bar, which is almost 100% stiffer than stock. My 22mm setup will be 109% stiffer than stock.
#18 | |
Drives: '22 BRZ
I've driven your car a bit, it can handle even more compression than that without issue. It's really nicely set up, curious how it goes for you on track instead of solely autocross.
| Tags |
| camber, suspension, toe |
| STX setup sharing thread (2022) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 204 | 06-15-2023 03:34 PM |
| The 2022 Autocross Thread | trippinbillies40 | Tracking / Autocross / HPDE / Drifting | 11 | 02-26-2023 06:13 AM |
| 2022+ BRZ STi Parts and Accessories Thread. | WorldRallyB | BRZ Second-Gen (2022+) — General Topics | 170 | 08-20-2022 12:47 PM |
| 2022+ Exhaust compilation thread | Yoshoobaroo | Engine, Exhaust, Transmission | 22 | 04-22-2022 07:17 AM |
| 2022 BRZ Dealer Stock Tip Thread | slipstream8 | BRZ Second-Gen (2022+) — General Topics | 12 | 12-06-2021 10:45 AM |
