Old 10-23-2022, 11:05 PM   #15
X25
Sr. Spiritual Advisor
X25's Avatar
Drives: 2023 BRZ Premium
Do you have a sway bar as well? I've just sourced sway bars, and will try their original recommended settings again, this time with 22mm Perrin sway bar at its soft setting (which is very close to what they asked for in recommend setup instructions).
After a lot of testing with that setup, I'll also test out a complementary 19mm rear bar. We'll see how it all works out
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4
'21 Tesla Y Long Range AWD
'19 Corvette Z06 Z07 (Track Build Thread)
X25 is offline   Reply With Quote
Old 10-23-2022, 11:58 PM   #16
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
Not sure who that was addressed to. If it was me, yes. I set it to 2/2 (max stiffness is 4/4). Front end response was too delayed at 1/1.
Wangspeed is offline   Reply With Quote
Old 10-24-2022, 12:02 AM   #17
X25
X25's Avatar
Yep, it was to you. I'm guessing it's Karcepts bar with that many settings? My baseline setup recommends 2/3 with that bar, which is almost 100% stiffer than stock. My 22mm setup will be 109% stiffer than stock.
Old 10-31-2022, 10:03 AM   #18
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I picked up a car that already had Karcepts MCS 2WNR w/ 400F/500R springs.
I've finally settled on this for sporty driving:
Front:
7 rebound / 4 compression
Rear:
9 rebound / 4 compression
Camber:
-3.5 F / -2.x R
Karcepts front bar on 2/2
This is with 17x9 Michelin PS4S in 245/40 @ 28psi. I still haven't made it to the track yet, but I doubt I will change it much there. Maybe a tad more rebound.
I really struggled to tame undulations with this setup. High speed shock movements like potholes and bumps are fine. Minor imperfections in the road can cause the car to jitter vertically. Letting a bunch of air out of the tires and bumping up compression helped.
I've driven your car a bit, it can handle even more compression than that without issue.
It's really nicely set up, curious how it goes for you on track instead of solely autocross.
camber, suspension, toe
STX setup sharing thread (2022) Autoxer62 Tracking / Autocross / HPDE / Drifting 204 06-15-2023 03:34 PM
The 2022 Autocross Thread trippinbillies40 Tracking / Autocross / HPDE / Drifting 11 02-26-2023 06:13 AM
2022+ BRZ STi Parts and Accessories Thread. WorldRallyB BRZ Second-Gen (2022+) — General Topics 170 08-20-2022 12:47 PM
2022+ Exhaust compilation thread Yoshoobaroo Engine, Exhaust, Transmission 22 04-22-2022 07:17 AM
2022 BRZ Dealer Stock Tip Thread slipstream8 BRZ Second-Gen (2022+) — General Topics 12 12-06-2021 10:45 AM
