#15 |
Drives: Crapcan
lol I just realized this is a no crank situation. There are so many of these threads right now, 4 by the same guy, I got confused.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#16 |
Somebody merged all those others and now it looks like we are all just repeating ourselves.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#17 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
When you say bounce around inside the car did it inch forward and then it started normally? I had a car that I always backed in places so that if the flywheel came to rest on the dead spot it had, I had to get it to rotate some by moving the car forward a few inches. Eventually I replaced flywheel but that was my work around for months.
#18 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | 2020BRZtS (09-21-2022) |
#19 |
Drives: JRSC BRZ SOLD
Jiggle the steering wheel off the column locks. If the wheel is on the locks it will not start.
#20 |
not playing cards
I don't care. The right people know what's up. Links still work.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (09-22-2022) |
#21 |
ProCrastinationConsultant
some of us just know what's down.
#22 | |
I checked the fuses and none were popped. Swapped #14 for a horn fuse with the same voltage, and it started! Turned it off, and then it didn’t want to start again. Swapped the fuse again (other horn fuse), it starts! Turn the car off, it doesn’t start AGAIN. Swapped the fuse for a third time with another good fuse (AC)…it starts. I drive it around after draining the transmission fluid a bit, that fixed the sluggishness. I park the car, turn it off…it doesn’t turn on AGAIN. I can hear a clicking around the location of the fuse box under the dash so I’m thinking that at least works. Swapped the relay with the dimmer relay and nothing. Tested the original starter relay (only the two vertical pegs, as I don’t have the tools to change them and test the horizontal ones for continuity) using Ohms, and the reading dropped to 0 or some lower numbers, fluctuating. Lastly I tested the starter wire like explained earlier using the chassis as a ground. Absolutely no reading when turning over the car. I did that before swapping all the fuses around, before I got the car running. Every time it didn’t want to turn back on I tested it and found no reading. Clutch switch, starter wiring harness, or relay? Take a guess lol or maybe something worse? Here’s a photo of the starter #14 fuse before swapping it for the horn fuse for the first time. |
#23 |
Drives: Chevrolet Ram 250
You should ohm out the fuses that you swapped out after it didn't start. Since you didn't do that I'm guessing you're blowing fuses and you have a short somewhere.
I got a smooth brain.
#24 |
not playing cards
Starter and battery will both be fine. You have a multimeter. Use it to check the fuses you've been swapping but it would be obvious from just looking at them. Something doesn't add up.
#25 |
If they’re slightly pink does that mean they’re burnt? They aren’t broken. Also, will a missing/bad turn signal cause a short? Or would it be more likely that it’s along the starter harness?
#26 |
not playing cards
Dunno for sure. Use the continuity or resistance mode on the multimeter, or use the horn socket as your fuse tester. I don't know what you mean by missing/bad. Which is it?
#27 |
#28 |
not playing cards
That's nothing. Test the fuses to be sure of those before moving on to investigate other causes.
| Tags |
| #trannyfluid #newclutch |
| Anybody running Exedy stage 2 clutch? | 14BRZ | Engine, Exhaust, Transmission | 65 | 05-26-2020 01:21 AM |
| Car will not go into gear after new clutch install?! | Amartinez99 | Engine, Exhaust, Transmission | 15 | 01-15-2018 02:25 PM |
| Feels sluggish after clutch pedal adjustment | brianhj | Engine, Exhaust, Transmission | 6 | 08-24-2013 01:58 PM |
| frs sluggish in first and second gear at 2k-4k rpm | M&W_FRS | Issues | Warranty | Recalls / TSB | 3 | 06-23-2013 04:09 PM |
| Sluggish/Stalling After aFe Intake Install | FR-S Matt | Engine, Exhaust, Transmission | 6 | 01-15-2013 09:57 PM |
