Old 08-21-2022, 10:59 AM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
my corner stops are loose.
think my hood bent itself
Old 08-21-2022, 01:53 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
The product called Liquid Moly is 180 and that is considered high.
Assembly lubes can go as high as 400 and should be diluted from there.
The samples posted are well above that.
My point remains that the guys that run home with their new car and drain out all that “crap” initial fill shouldn’t be in such a rush.
https://www.liqui-moly.com/fileadmin...Molygen_EN.pdf
Ah! I see your point! [/threadjack]
I have known about this hood flapping effect since the very beginning and with all the meets I've attended, never thought to ask others in person.
Do the hood and fender lines match? Mine do nicely. Is it possible that the front clip is high? I'm talking about the hardware that screws together over the radiator and such. Not sure if I'm using the right terms.
Old 08-21-2022, 02:10 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I can’t see my hood while driving. Problem solved.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
sato (07-06-2025), soundman98 (08-21-2022), Ultramaroon (08-21-2022), villainous_frx (08-21-2022), x808drifter (08-22-2022)
Old 08-21-2022, 03:16 PM   #18
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My hood matches the fender down the sides. By "flapping" I see more of a vibration visible at the passenger side edge of the hood. I either need to be looking for it, or the sun needs to be reflecting off the edge of the fender just right. I think for a while I had my hood stops a bit too high and maybe the front corners warped a bit over time?
My eventual solution will be latches and/or vents, but I'm procrastinating to see how much I actually want to mod the frs lol. 9 years and counting...
The Following User Says Thank You to Spuds For This Useful Post:
Old 08-21-2022, 04:12 PM   #19
soundman98
soundman98's Avatar
my hood doesn't 'flutter' or 'flap' per se.
the sides of the hood forward of the strut humps will visibly raise up from the quarter panels about a 1/4"-1/2" at any speed over about 45mph. air is definitely running over the top of the headlights and raising up the hood
lately i've noticed that the hood towards the front is about 1/8" raised over the side panels, and i could've sworn it was closer to flush/even when i originally got the car.
my plastic front bumper, i've got no issues with alignment with the hood for that. but my plastic bumper cover is also pretty loose from curb strikes, so any alignment issues there are pretty easily faulted elsewhere.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Spuds (08-21-2022), Ultramaroon (08-21-2022)
Old 08-21-2022, 04:33 PM   #20
Brz-123
Is this Moly concentration in Engine oil? In UK we have a very popular oil brand called Millers and this is their used oil sample analysis for my car. I have a few more, always Moly around 1000 PPM. Name:  Screenshot_20220821-213140_Gallery.jpg
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 08-21-2022, 05:48 PM   #21
Ultramaroon
not playing cards
THIS IS NOW A BITOG THREAD
Maybe the corner stops are too high. I've never tried to see how far I can lower mine before they no longer touch the hood when latched. Hmmm...
Old 07-01-2023, 07:00 PM   #22
ajaxburger
ajaxburger's Avatar
Drives: 2017 BRZ Limited Perf. Pack
What if you are at the bottom and still get flutter?
Double check that the small rubber bumpers out on the edges of the hood are adjusted too. These can help with fluttering out near the sides.
zoom zoom... wait wrong company
ajaxburger is offline   Reply With Quote
Old 07-01-2023, 10:45 PM   #23
whataboutbob
AutoX-10/10ths every run
Maybe slow down? :P
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
sato (07-06-2025)
Old 07-17-2023, 09:49 PM   #24
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Looks pretty stable in this video, but maybe it is not showing the area that flutters?
LRNAD90 is offline   Reply With Quote
Old 07-17-2023, 11:47 PM   #25
LRNAD90
Though I have to admit, I always wondered about this gap above the headlamp and if it was sealed off to air flow or not. If not, maybe that is the issue?
(Yeah, I know the frontbumper is not fitting correclty in this photo, but it was the best one I could find quicklyh to show the gap I described)
Old 07-18-2023, 12:03 AM   #26
Ultramaroon
not playing cards
There are seals, little angled flappy things mounted to the underside of the hood to route the air around the corners. I don't know how effective they are or if they're even in play here.
Old 07-18-2023, 09:38 AM   #27
Spuds
The Dictater
Spuds's Avatar
Stone. Guards.
...I'll see myself out...
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
The Following 4 Users Say Thank You to Spuds For This Useful Post:
Jdmjunkie (07-18-2023), MICHAEL450f (07-18-2023), soundman98 (07-18-2023), Ultramaroon (07-18-2023)
Old 07-18-2023, 07:14 PM   #28
norcalpb
norcalpb's Avatar
Raise the corner stops. Too low it will flutter, too high it’ll look stupid. All about finding that middle ground.
FS: Seibon Carbon TS hood, Sparco hood pins, Clear coated $650 (Lawndale) iceblaze Southern California 1 04-14-2019 03:50 PM
Random fluttering/flapping sound when coming to a stop retrosmiths Issues | Warranty | Recalls / TSB 24 10-08-2014 03:13 PM
Constant flapping sound from rear wheel side? djmm Scion FR-S / Toyota 86 GT86 General Forum 12 08-11-2014 09:36 AM
flapping noise meekhotglass BRZ First-Gen (2012+) — General Topics 38 05-02-2013 10:44 AM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 09:27 PM
