Old 06-18-2022, 03:21 PM   #15
Personally, I'd just spin the wheel and listen. If you hear anything at all, even the slightest sound, the hub assembly is toast. Can't stress enough that bearings MUST run dead silent.
I would pull the wheel to remove the possibility that the noise he mentioned is indeed something rubbing. Isolating the hub will make it easier to hear if actually a bearing issue. Also give a chance to check it isn’t a brake or dust shield that is out of place.
blakkoutdarko (06-18-2022), Ultramaroon (06-18-2022)
Old 06-18-2022, 06:59 PM   #16
blakkoutdarko
blakkoutdarko's Avatar
Drives: 2017 Toyota 86 (Raven)
Originally Posted by RedReplicant View Post
My point was that the stock stamped steel arms will bend in an impact, but generally preserve the subframe. Something like a SPL may very well transfer that impact force into the subframe and bend it too.
ahh okay thanks for the input will definitely be considering that if i ever want to upgrade the arms. but i’m just going to continue to run OEM parts for now
blakkoutdarko is offline   Reply With Quote
Old 06-18-2022, 08:39 PM   #17
Grady
Grady's Avatar
On the hub I would take it off and feel it. If it is early damage you will have a better chance of feeling the damage over hearing it. It should be smooth as you rotate it if you feel any roughness I would replace.
The Following 2 Users Say Thank You to Grady For This Useful Post:
blakkoutdarko (06-19-2022), Ultramaroon (06-18-2022)
Spun a bearing, what parts do I need to replace? Daisies Scion FR-S / Toyota 86 GT86 General Forum 3 05-16-2022 12:29 PM
What parts would I need to completely replace entire suspension system? echomx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 09-04-2020 11:47 AM
Having accident causing persons insurance replace aftermarket parts Chuckls BRZ First-Gen (2012+) — General Topics 37 02-03-2020 12:37 PM
What to check after swinging it Youngmanhenry Scion FR-S / Toyota 86 GT86 General Forum 47 04-06-2019 12:54 AM
What additional parts do I need to replace with my kaaz lsd install acpstunts Engine, Exhaust, Transmission 0 04-06-2017 11:43 PM
