Old 05-08-2022, 08:56 AM   #1
Daisies
Drives: 2016 Subaru BRZ Limited
Spun a bearing, what parts do I need to replace?
Hello, I’ve used this forum off and on to look a some things I wanted to know, but the time has come that I need to ask a question. I couldn’t find a topic in this specifically, and if this is the wrong place I apologize.
I spun a bearing on Easter Sunday, low oil pressure was the cause. Unsure what caused the pressure to be low but the shop will be in it shortly when I bring it to them.
Parts I was using:
IAG Stage 1 w low compression.
HKS oil cooler (temps were at 150-160° average and at this specific time was at 156°)
5w40 300v oil
JDL Turbo kit
Killer B oil pickup
I’ve recently purchased a stage 2 w low compression and will be here shortly. I’m searching for a new oil cooler, no big deal.
It’s everything else.
Oil pump, should I do that upgraded gear or no?
Do I need to replace my oil pan?
I’ve never blew an engine before so this is upsetting but I’m willing to have it all replaced at my expense. I’ll be sending it to AllPro Subaru shortly. I just want to get these parts in before I do so, less of a wait time maybe?
Daisies is offline   Reply With Quote
Old 05-08-2022, 12:19 PM   #2
PulsarBeeerz
Drives: JRSC BRZ SOLD
Whoa, I thought the IAG blocks were modified to cure low oil pressure events?
PulsarBeeerz is offline   Reply With Quote
Old 05-08-2022, 03:59 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Cure, no. Help, yes.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 05-16-2022, 11:29 AM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
IAG has a 1 year warrantee. They have very specific oil change intervals and you have to use 0-20 Motul. If you’re more than a year out then warranty is expired. That is what it was on mine however I stayed NA so maybe FI is different.
Spun Rod Bearing? itsAlex Issues | Warranty | Recalls / TSB 38 03-12-2021 09:03 PM
2013 FR-S Spun Bearing kyjondeere Issues | Warranty | Recalls / TSB 1 09-14-2018 09:24 AM
Need help, spun rod bearing, vvt parts missing faninos Issues | Warranty | Recalls / TSB 3 07-12-2018 03:11 PM
Spun Rod Bearing #4 KE70 Issues | Warranty | Recalls / TSB 13 07-05-2016 03:17 PM
Likely hood of a spun bearing aquaman Engine, Exhaust, Transmission 14 02-24-2016 01:37 PM
