Old 06-12-2022, 02:02 AM   #15
Limitz
Drives: Black Scion FR-S
It's exactly that.
I see, my mechanic said he was gonna run some test ima tell him to start with the throttle body maybe he finds something? Or at that point do you gotta replace the whole throttle body? Obviously when I don’t press the gas the throttle body stays closed
I think the flutter only happens when I try to turn my key
Limitz is offline   Reply With Quote
Old 06-12-2022, 02:58 AM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
Just let your mechanic do his thing. It might not actually be the throttle body. It's possible that something else is telling it to act wacky. Sounds like he's on the case.
Old 06-12-2022, 09:54 AM   #17
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
So my mechanic came to check it out quick since he couldn’t run lots of test on it since he didn’t have time, but we did get multiple misfire codes, an air sensor code,but he believes it to have something to do with the throttle body since I’ve had an issue with it before. ima check if disconnecting battery for a while then plugging it back in will turn the car on. Car just cranks now and doesn’t want to turn on. Ive also had some problems with the battery, and apparently a fuze is going bad. I thought maybe I didn’t put the correct gas but I’m 99% sure I used 91 octane .. which is what it takes, I don’t think I would mess that up, but still a possibility.
Hmmmm...
Wally86 (06-13-2022)
Old 06-12-2022, 04:07 PM   #18
humfrz
Reminds me of situations back in the day ( @Tcoat and @Ultramaroon ) will remember, when detergent oil was introduced. People would put the "new type" of oil in their old engines to "clean" them.
Well, it "cleaned" them alright ...... and the engines started burning oil, valve trains started loudly chattering and rods started making knocking sounds.
just sayen -
Tcoat (06-12-2022), Ultramaroon (06-12-2022)
Old 06-12-2022, 05:27 PM   #19
Sapphireho
Famous Potatoes
Sapphireho's Avatar
It was tide?
Icecreamtruk (06-14-2022)
Old 06-12-2022, 06:15 PM   #20
Ultramaroon
not playing cards
How prophetic -__-
bcj (06-13-2022), Icecreamtruk (06-14-2022), soundman98 (06-12-2022)
Old 06-13-2022, 02:59 PM   #21
Limitz
just sayen -
Yeahhh I get what you mean, my guess is that the fuel filter is clogged, plus this car has 105,000 miles and I’m sure the old owner didn’t change the fuel filter, I have a feeling it’s just going to be my fuel filter clogged and not feeding fuel to the engine for startup
The Following User Says Thank You to Limitz For This Useful Post:
humfrz (06-13-2022)
Old 06-13-2022, 03:06 PM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can see a lot of those types of fields using a bluetooth OBD2 reader and an app like torque. I use it quite a bit to figure out issues and have a cheap tablet dedicated to using in the shop. Codes a lot of times, are symptoms and not the actual problem. It's kind of like your car saying "my stomach hurts."
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (06-13-2022)
How to Fix Limp Mode? MidnightFumes Issues | Warranty | Recalls / TSB 7 01-20-2021 05:18 PM
Limp mode at 2K rpm NEED HELP!! Arthur_frs Engine, Exhaust, Transmission 5 04-13-2020 10:22 PM
Limp mode GTBOY Issues | Warranty | Recalls / TSB 4 06-07-2018 12:58 PM
Valet mode / limp mode? radroach Software Tuning 1 09-18-2017 11:34 AM
Car in Limp mode... No CEL Sportsguy83 Issues | Warranty | Recalls / TSB 60 08-20-2014 03:35 AM
