Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 05-25-2022, 06:20 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
A few years back I did a comparison between 10 downable apps and my $1000 professional, calibrated, dB meter.
Turns out that 7 out of 10 were within a dB or so, 2 were off by about 10dB and one wasn't even close enough to say it worked. All were measured at the exact same distance and conditions.
All in all they were at par or better than the couple of $50 meters we had.
I had a lot of issues with the few we tried unless we could get really far away from anything that would reflect sound. The apps seemed way more sensitive to echo.
Old 05-25-2022, 06:27 PM   #16
Reflected noise would have the same effect on an actual meter though. It can always be tricky.
Old 05-25-2022, 06:36 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I guess I should say consistency, not accuracy. We were using the automotive standard of X inches at 45 degree so far away from a structure and I couldn’t get far enough away in our parking lot to get repeated readings. Had to go down the street to a Harbor Freight and use their lot.
Old 05-25-2022, 06:45 PM   #18
Ahhhh
Old 05-25-2022, 06:49 PM   #19
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
You guys are forgetting that sound meters must be calibrated with a tone generator. I have a custom muffler delete on my 2nd Gen BRZ, very much the same results as the remark. Loud on startup, which is to do with the catalytic converters, loud when you stand on it or rev it in neutral, but completely livable on the highway for long trips. If you are worried about your neighbours, don't do a muffler delete, it's that simple. I feel bad when I start mine super late at night, but I've gotten good at quickly backing out of the garage which helps to lower the volume. It also absolutely does NOT sound like a riced out Honda, has a very distinctive tone and have gotten lots of positive feedback from other competitors at autocross. I run consistently below 90DB at autocross as well, these readings are taken at 50ft away, about 4ft up on a stand, which is consistent with SCCA standards for sound testing at autocross and race tracks.
Midnightsky is offline   Reply With Quote
The Following 2 Users Say Thank You to Midnightsky For This Useful Post:
MikeNSX2 (05-25-2022), NoHaveMSG (05-25-2022)
Old 05-25-2022, 08:06 PM   #20
MikeNSX2
Drives: Ice Silver 2022 BRZ Limited
I agree.
It's surprising some here are so critical about a muffler delete system for a 2022 BRZ, but have never actually heard one in person.
MikeNSX2 is offline   Reply With Quote
Old 05-25-2022, 08:21 PM   #21
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
I've got fairly adept at rolling the car out of the garage with one foot out the door, and then starting it on the driveway. My garage floor is pretty sloped which helps.
I've got a muffler, but it still shakes everything in the garage when I start it inside, which is not ideal late at night.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
The Following User Says Thank You to 22 BRZ For This Useful Post:
Midnightsky (05-25-2022)
Nameless Axle back Muffler Delete With Stock Midpipe dattran86 Engine, Exhaust, Transmission 9 08-15-2016 01:33 PM
Brand new axle back + muffler delete Higher Being Engine, Exhaust, Bolt-Ons 6 02-17-2016 09:05 PM
WTB: axle back / dual muffler delete nadbrz Want-To-Buy Requests 0 07-30-2015 06:40 PM
Works AB-R Resonated Axle Back Muffler Delete cdo221 Engine, Exhaust, Bolt-Ons 20 03-22-2013 03:24 AM
