Old 08-14-2016, 10:18 PM   #1
dattran86
Driver
Drives: 2013 Whiteout FRS
Nameless Axle back Muffler Delete With Stock Midpipe
Hi,
I'm looking to install the Nameless Muffler delete axle back on my car. Im just wondering how much louder the car will be?
It is tolerable as a daily driver? do anyone have the same set up as this?
thanks
dattran86 is offline   Reply With Quote
Old 08-14-2016, 10:46 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by dattran86 View Post
Hi,
thanks
I have it with a CNT uel header and my axleback is 3 inches with 5 inch mufflers, absolutely no drone and has a perfect tone:
[ame="https://www.youtube.com/watch?v=YjU09Z1zXRo"]CNT UEL And Nameless 3 inch axleback - YouTube[/ame]
I can't personally recommend my 3 inch however, I would HIGHLY recommend the 2.5 inch for the stock mid pipe and entire exhaust unless you have a forced induction setup planned for two reasons:
1) Nameless claimed it would fit perfectly with the stock 2.5 inch mid-pipe, turned out it didn't and had a slight leak, required a grimmspeed exhaust gasket and permatex ultra copper rtv exhaust sealant on both sides of the gasket. Buying the 2.5 inch with 5 inch mufflers is the best bet to avoid this unless you end up buying there full exhaust
2)It took over one month for it to get to me. had it been the 2.5 inch it would've arrived much quicker, it's also important to note Nameless builds to order. Therefore they are limited by that and have to wait for materials. To counter this simply email them before ordering to be sure of the arrival date
With those small gripes however I have to say this, and it can be avoided buy simply buying the 2.5 inch:
1) It has really really good build quality weld have no fish eyes, and the entire thing has a nice look and you can peak at those perpendicular cans from behind.
2) It sounds glorious and they managed to get no drone with the two mufflers.
I wouldn't recommend a muffler delete btw, unless you plan on not adding any other exhaust mods. Otherwise it would be a perfect fit.
Old 08-14-2016, 11:03 PM   #3
humfrz
Hi,
thanks
Hello @dattran86 and welcome to our fine forum.......
Good choice for an aftermarket muffler system. However, you may wish to re-think the "delete" part.
I have a stock exhaust system, except for a nameless axle back, with 2.5" piping and 5" mufflers and I consider is loud enough. Under power, it kind of says "I'm here" but, it doesn't shout "look at me".
If your going to use your car as a DD and would still like to hear your radio and other peoples conversation ...... I'd go with either the 5" or 4" mufflers.
humfrz
Old 08-14-2016, 11:43 PM   #4
brzfl
Drives: 2015 CWP BRZ Limited
That sounds absolutely amazing... Might have convinced me to change my exhaust set up...
Also what are your thoughts on the CNT UEL?
brzfl is offline   Reply With Quote
Old 08-14-2016, 11:56 PM   #5
FRSBRZGT86FAN
CNT uel is awesome for the budget you can't beat it, all the first production batch issues with leaks and fitment are pretty much gone.
Old 08-15-2016, 12:08 AM   #6
brzfl
Sounds amazing too, thanks man!
Old 08-15-2016, 12:35 AM   #7
dattran86
Driver
I actually been running 3in catback from nameless including the muffler delete axle back for a couple of week.
It is very loud. I dont mind loud exhaust but mine is a little too loud for long driving.
So im planning to take the nameless midpipe off and replace it with my stock mid pipe.
Old 08-15-2016, 12:37 AM   #8
dattran86
Driver
Thanks for the reply
i am actually not planning on any other exhaust related like front pipe or header. that will probably be 2-3 years down the road.
So im assuming I should be alright until i decided to upgrade other exhaust parts?
Old 08-15-2016, 08:24 AM   #9
15limited
15limited's Avatar
Hi,
thanks
I'm confused 😬
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 08-15-2016, 12:33 PM   #10
humfrz
Originally Posted by 15limited View Post
I'm confused 😬
I think the OP is confused .........
humfrz
exhaust, frs
Brand new axle back + muffler delete Higher Being Engine, Exhaust, Bolt-Ons 6 02-17-2016 08:05 PM
SOLD: Nameless Axle Back 2.5inch w/ 4" Muffler zc06_kisstherain Want-To-Buy Requests 16 08-01-2015 02:11 PM
WTB: axle back / dual muffler delete nadbrz Want-To-Buy Requests 0 07-30-2015 05:40 PM
SOLD: Nameless Axle Back 4" muffler zc06_kisstherain NY / NJ / CT / PA 4 07-13-2015 09:34 AM
Works AB-R Resonated Axle Back Muffler Delete cdo221 Engine, Exhaust, Bolt-Ons 20 03-22-2013 02:24 AM
