Old 07-14-2022, 01:59 PM   #15
DarkSunrise
DarkSunrise's Avatar
Originally Posted by Racecomp Engineering View Post
The ride quality is very good, better than OEM 2016 dampers by a significant margin. It's downright comfortable. This is on really awful Baltimore city roads and long trips to the mountains. It's likely better than 2017-2020 dampers too. Better than Bilstein B6, Koni, etc. Almost like a normal car.
Which...I do not love in terms of handling and feel. It's a little sloppy and not very confidence inspiring, especially the rear. This isn't just me going from those 3 ways to an OEM suspension. I would still prefer the 22 dampers to any of the 1st gen OEM dampers and a lightly used set of these would be a good choice for someone looking for more comfort.
Just some quick thoughts.
- Andrew
Yeah I was surprised at how comfortable the oem suspension on the 22 BRZ was compared to my returned-to-stock 13 FR-S. The 2013 feels almost crashy and dare I say overdamped in comparison, but firmer and more responsive when pushed.
I’m constantly tempted to throw my RCE T2’s on my 22 BRZ (they’ll go on eventually), but for now I’m enjoying the comfort level on the oem 22 suspension.
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
Racecomp Engineering (07-14-2022), treedodger (07-27-2022), wparsons (02-22-2023)
Old 07-14-2022, 04:32 PM   #16
marco_mc22
Drives: Toyota 86
Random update that may interest someone...
In between testing some 3 way coilovers and other fun stuff, I've put the 2022 BRZ dampers and springs on my 2016 BRZ. Just for kicks. The car is otherwise now almost completely stock suspension wise (boooring) with the exception of OEM crash bolts, my bling STI strut bar, and rear Whiteline subframe + diff bushing inserts.
- Andrew
When you say 2017-2020 dampers you mean Showa base or PP Sachs?
marco_mc22 is offline   Reply With Quote
Old 07-14-2022, 05:04 PM   #17
I think it rides better than both.
- Andrew
Old 07-21-2022, 02:41 PM   #18
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
But does the 22 suspension oversteer when you sneeze like the 13 FRS does stock?
Old 07-22-2022, 11:36 AM   #19
It does not lol. I would not describe it as prone to oversteer at all.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
EAGLE5 (07-22-2022)
Old 02-13-2023, 04:20 PM   #20
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
Do you know the bar rate on the RSB for the GR86? I found you post elsewhere the 14MM is 113lbs in reference to the old cars but having trouble with googlefoo on the 15MM bar the 17+ cars had.
MacSpeed is offline   Reply With Quote
Old 02-13-2023, 04:59 PM   #21
Ohio Enthusiast
Drives: 2018 BRZ
I believe sway bars increase stiffness with the 4th power of thickness, so 15/14 = 1.071 (or 7% increase in diameter) results in a 31.6% stiffer bar.
Ohio Enthusiast is offline   Reply With Quote
The Following 4 Users Say Thank You to Ohio Enthusiast For This Useful Post:
MacSpeed (02-13-2023), Ruben_86_ (02-16-2023), ruturaj001 (02-17-2025)
Old 05-20-2023, 11:40 AM   #22
Mike Roadway
Drives: 2023 BRZ Limited 6MT
Suspension frequencies:
Using a 55/45 weight split and 3000 lbs with driver, we get roughly:
BRZ – 1.47 Hz front and 1.42 Hz rear.
GR86 – 1.42 Hz front and 1.50 Hz rear.
AWESOME thread and data, thanks @Racecomp Engineering. I started working the frequency ratios on my own and stumbled on this — I appreciate the detail.
Mike Roadway is offline   Reply With Quote
The Following User Says Thank You to Mike Roadway For This Useful Post:
Racecomp Engineering (05-20-2023)
Old 07-26-2023, 04:46 AM   #23
ffh2303
Drives: BRZ 2013
- Andrew
Hi, with the MY22 suspension does the ride height increase or decrease on the MY16 BRZ? Asking this since I read somewhere the MY22 rides 10mm lower.
ffh2303 is offline   Reply With Quote
Old 07-26-2023, 11:52 AM   #24
Hmmm...I didn't measure ride height unfortunately and don't have any pics. It looked "stock."
I may have been overselling the comfort just a tad...it's good and better than anything first gen by a little bit...but not amazing/plush.
I do think it's worth replacing old and tired first gen parts with 2nd gen BRZ parts if you get a good deal and don't want to try anything aftermarket.
- Andrew
Old 07-28-2023, 10:01 AM   #25
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Andrew I know you said in the other "shared parts" thread that the rear tophats are different, but is there a combination of parts that would allow me to pair gen2 dampers with gen1 tS springs on my 2019 BRZ?
I want to pair the 2024 tS Hitachi dampers with my tS springs - hoping it will be more comfortable than my current Bilstein B6 & tS spring combo which tosses me around quite a bit on broken roads. My buddy and I compared his 2022 BRZ with my car and the new car is definitely more comfortable.
-David
N_Raged is offline   Reply With Quote
Old 07-28-2023, 10:15 AM   #26
-David
Hmmm not sure of the exact difference in the rear top hat, but I haven't tried putting a rear 1st gen spring on 2nd gen shocks. It's not "supposed" to work.
We're interested to see how the Hitachi dampers do and how they'll compare to standard and also the GR86 Sachs dampers.
- Andrew
Old 07-28-2023, 11:35 AM   #27
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I believe the top hat is the same but I know for sure that the perch on the shock is different.
The Following User Says Thank You to DocWalt For This Useful Post:
Racecomp Engineering (07-28-2023)
Old 07-28-2023, 01:15 PM   #28
N_Raged
nuts, okay thanks
Standard Suspension Bump Travel 86•BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 87 07-26-2017 11:33 AM
Raceseng Shock Top - Rear Upper Shock Mount with 1” Increased Travel RJasonKlein Brakes, Suspension, Chassis 2 01-18-2017 04:33 PM
More rear suspension travel Hyper4mance2k Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-24-2016 08:13 PM
RallySport Direct's Mega Suspension Everything Thread!!! RallySport Direct Brakes, Suspension, Chassis 101 07-01-2015 11:01 AM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
