#15 | |
I will say that I have never kept stock lug nuts. |
#16 |
Drives: Subaru BRZ
https://www.boltscience.com/pages/strength.htm
Interesting read. Sent from my SM-G973F using Tapatalk |
#17 | |
Drives: 2022 GR86
While the brake rotor is off, might consider replacing all five studs on that corner. A couple of "special" tools that come handy to replace studs: 1) https://www.amazon.com/gp/product/B003YVWHOE/ to push the old stud out (use an impact gun) 2) https://www.amazon.com/gp/product/B000ETUD22/ to pull the new stud Pushing the old studs out is easy, but it wasn't trivial to pull the new front studs while the rotor is off. The problem is that the ball bearing just spins whenever you try to apply any significant torque to a lug nut. In the rear you can use the handbrake, but not in the front. I don't remember how I ended up pulling them, but I think I tried using an impact gun, and the thread on my brand new studs ended up being a bit damaged. You might consider buying a set of cheap throwaway lug nuts to pull the new stud(s). This way if at any point you apply too much force to the new stud, it's the lug nut that gives. If you're only going to replace a single stud, you might try putting the rotor and caliper back on, asking a helper to press the brake pedal, and then just turning a lug on the stud with a ratchet. |
#18 |
I appreciate everyone's input. I did it today relatively fast actually, turned out to be easier than I was expecting. Is it okay to use an OEM lug on an aftermarket wheel while I try to get a new Mishimoto lug? From what I've tried researching on here, it seems to be alright because the OEM lugs are conical like the Mishimoto ones I have right now. I just want to double-check.
#19 | |
TRACKBREAD
Yea its fine. |
#20 |
Dismember
Drives: 2013 Red Scion FR-S
I use hand tools. Mallet and a punch to remove broken lugs. Washers, lug, and hand ratchet to install. I guess it helps to have lugnuts that go through, or you can just get more washers.
The hardest part is removing the brake caliper. There are two screw holes that you drive the right-sized screws into. I had two of them from a TV mount install kit, so no problem. Open lugs have the advantage of debris falling out easier, and being easier to clean. Might prevent some failures. Also they look pretty cool.
| What is this kit, and what is it missing? | beloden | Forced Induction | 13 | 04-20-2020 06:41 PM |
| missing under panel | maithem86 | Issues | Warranty | Recalls / TSB | 2 | 07-25-2017 06:20 PM |
| Missing??? | Papi | BRZ First-Gen (2012+) General Topics | 17 | 06-23-2015 02:08 PM |
| So... am I missing something? | BirdTRD | Issues | Warranty | Recalls / TSB | 10 | 11-04-2013 04:52 PM |
| missing my FRS :( | 20valvewynn83 | Southern California | 36 | 08-29-2012 03:12 AM |
