Old 10-08-2021, 02:22 PM   #15
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Originally Posted by adrianj73 View Post
The products are loaded into my cart on your page. The first drop down for options selection drop down box does not have MCS in the list although the second drop down box for shaft size does.
Fixed!
Thanks for catching that.
949 Racing is offline   Reply With Quote
Old 10-08-2021, 09:12 PM   #16
adrianj73
Drives: '13 FRS
Originally Posted by 949 Racing View Post
Fixed!
Thank you! Order placed.
adrianj73 is offline   Reply With Quote
Old 05-03-2023, 06:37 PM   #17
949 Racing
949 Racing's Avatar
Two years and still the most affordable true coaxial perch camber plates and rear shock mounts.
The Following User Says Thank You to 949 Racing For This Useful Post:
RedReplicant (05-03-2023)
Old 05-04-2023, 04:06 AM   #18
Breezer
I would like an adapter for an OEM rear mount that retains the Xida upper perch cup & cone interface.
Are there plans to make any type of rear OEM mount adapter?
Breezer is offline   Reply With Quote
Old 05-05-2023, 01:29 PM   #19
949 Racing
949 Racing's Avatar
No plans to make an adapter from OEM mounts to race springs, sorry.
Old 05-13-2023, 04:46 PM   #20
nomtimesthree
Drives: GR86
How are these for noise? I know with any camber plate there will be some NVH increase over stock, but I've had plates that are nearly silent most of the time and some which clunk a lot. Are these okay for street use in that regard?
nomtimesthree is offline   Reply With Quote
Old 05-13-2023, 06:21 PM   #21
949 Racing
949 Racing's Avatar
We have not noticed any noise on our cars nor have any of our customers reported noise.
edit: I should also point out that we have been using these same bearings in our Miata kits for almost a decade and never had a customer report a worn or clunking bearing. They're robust.
nomtimesthree (05-13-2023)
Old 06-18-2023, 06:40 PM   #22
redlined600
redlined600's Avatar
Drives: Fr-s
Do you have a measurement from the top of the mounting surface to the bottom of the spring seat? I'd like to know how much shorter they are than my current camber plates.
Thanks
Old 06-18-2023, 07:31 PM   #23
949 Racing
949 Racing's Avatar
Thanks
Shoot Ed an email for detailed specs. They are shorter stack height than any other camber plate on the market.
What camber plates / top mounts for Ohlins? Jakecox86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 02-28-2019 03:28 AM
FS: Moore Sport Front Camber Plates & Rear Top Mounts Scracho Canada Classifieds 10 04-21-2018 04:59 PM
Raceseng | Billet Aluminum Caster Camber Plates Raceseng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 162 12-29-2014 11:32 AM
Color options Camber Plates, Stress Bar, & Shock Mounts GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-26-2013 02:08 PM
