Old 08-30-2021, 02:55 PM   #15
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Got off the phone with the people at GrimmSpeed and no it is not needed.
ARP says its up to the manufacturer of headgasket.
irax is offline   Reply With Quote
The Following User Says Thank You to irax For This Useful Post:
blsfrs (08-31-2021)
Old 08-30-2021, 04:43 PM   #16
Tokay444
This has less to do with the head gasket and more to do with the head studs used.
The Following User Says Thank You to Tokay444 For This Useful Post:
humfrz (08-31-2021)
Old 08-31-2021, 02:12 AM   #17
humfrz
Bubba wants ta know ...... what the hell does tightening the head bolts down have to do with the head gasket? It don't take hardly any torque to mash one of them flat, no matter what they are made of.
Bubba says to just tighten the head bolts down gutten-tight (head bolt tight).
Then he just turned around and shook his head - although I said I was just asking for a friend -
Old 08-31-2021, 12:24 PM   #18
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
The whole process of tightening the head bolts on an FA20 seems like a combination of the Hokie-Pokie and Musical chairs
Old 08-31-2021, 01:28 PM   #19
irax
irax's Avatar
Okay, you can call ARP and tell them they are wrong
It's not just about fatigue of the head bolts, its about the head gasket compression due to heat cycle.
The last time I did this was when I replaced the head gasket on my KA24DE and its rather easy to do on that engine. You take off the valve cover and just boom its right there. Haynes guide deferred to the head gasket instructions. Head gasket manufacturer (FELPRO) recommended retorquing the head bolts after the first engine heat cycle after installing the head gasket.
The FA20 you have to take the motor out of the car or lift it or lower it for access, first you remove all the accessories bolted to the timing cover, then take off the timing cover, remove the timing chains and tensioners, remove the valve covers, and then remove the cam girdles, then you retorque the head bolts. Then you install the cam girdles, install the timing chains and tensioners, reset the timing, install the timing cover, and the finally reinstall all the accessories.
Old 08-31-2021, 07:20 PM   #20
Tokay444
And what if you use an OE head gasket and 625AGE studs?
Old 08-31-2021, 11:52 PM   #21
irax
irax's Avatar
Sorry, when I called I only asked about the 2000 and not the 625.
But here's the instructions for the EJ with the 625 kit. Doesn't mention retorquing bolts after first heat cycle. https://tech.arp-bolts.com/instructions/260-4704.pdf
I didn't rebuild the motor my self. I paid a shop to do it so I didn't get a copy of the instructions. The builder is hard to get a hold of and the engine break in sheet he gave me was rather generic.
Here is the link to the 2000 kit.
https://tech.arp-bolts.com/instructions/260-4301.pdf
OE bolts are Torque to Angle
https://gt86stuff.onrender.com/t3Por...22984209176356
I know TTA bolts are not retorqued, but my limited experience with TTY may be. So hence the thread. There wasn't anything on the forum, so I guess now there is.
blsfrs (09-01-2021)
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 01-29-2021 11:53 AM
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 09:06 PM
ARP rod bolts Grip Ronin Engine, Exhaust, Transmission 6 09-10-2015 10:22 AM
86 with bolts on ! Like the BRZ TS asnoir Scion FR-S / Toyota 86 GT86 General Forum 1 08-12-2014 05:14 PM
Camber bolts Kosmos Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-08-2014 11:15 PM
