Old 05-26-2021, 09:40 PM   #15
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
For this car you would really need to go nuts and do everything. Not worth it IMO, put music louder or get a nice exhaust to listen too, you will not make this car a Lexus. But go for it.
Ernest72 is offline   Reply With Quote
Old 05-29-2021, 12:05 PM   #16
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
I disagree that you have to go nuts. I've only done the trunk and back seat area with a minimal application of Dynamat so far, and there's been a nice difference. Sure it'll never be a Lexus, but if I can take the edge off the road noise, with a minimal weight gain (<30lb total) that'll be satisfactory.
Cephas is offline   Reply With Quote
Old 05-29-2021, 02:34 PM   #17
soundman98
ProCrastinationConsultant
soundman98's Avatar
the only thing i've sound dampened was the trunk lid and rear parcel shelf. and only because i could hear both of them rattling all the time. the rest of the car i haven't touched and don't see a significant need to.
Old 06-07-2021, 08:42 PM   #18
Ernest72
For rattles I totally agree. I have some dynamat in key places that seemed to make noise. But this car is light and tinny.
The Following User Says Thank You to Ernest72 For This Useful Post:
soundman98 (06-07-2021)
Old 12-02-2021, 04:51 PM   #19
Lav
Drives: Frs
it's all really the same-- the differences are going to be brand recognition, and possibly deading material thickness. it's all butyl rubber with an aluminum foil skin that works by mass loading panels to lower their resonate frequency.
the main thing is to understand the fundamental aspect of how it works, and you can save a significant amount of money over the 'standard' way of lathering it everywhere.
i posted this before, but it perfectly sums up the wrong and right way to use sound deadening:
https://www.ft86club.com/forums/show...=143757&page=2
out of those 2 pictures, they're going to really work the same, but the first picture cost at least twice as much, and took twice as long, and added much more weight, for the same end result.
sry, asking the same question here (https://www.ft86club.com/forums/show...2&postcount=48) since this thread is specifically on sound proofing:
Does this approach work just as well for general sound deadening? or is it just for killing resonance for better audio quality. I'm trying to make my car quieter from road/wind/tire noise
EDIT UPDATE since I may as well update both comments:
Edit: I ended up doing it like #2. Out of lazyness more than anything else. I'm gonna measure it now
Edit with update "measurements" on a Samsung S20 FE with some app. 76db going 70mph with the seats up became 73db going 70mph with the seats up. Seats down measurements were basically the same, and 80mph the measurements were basically the same. I am very wary of "placebo-ing" myself, but listening to afunkydiabetic on youtube (a talker) I find myself setting the volume in the 30s now instead of the 50s. This is true months later. I used to always have volume in the 50s with my phone volume all the way up. Subjectively it seems quite a bit quieter.
Lav is offline   Reply With Quote
Old 12-04-2021, 02:04 PM   #20
Cephas
Cephas's Avatar
I've done it exclusively to make the car quieter, actually. Any improvement in audio quality is just icing on the cake.
The Following User Says Thank You to Cephas For This Useful Post:
Lav (04-13-2022)
Old 12-08-2021, 09:39 PM   #21
soundman98
soundman98's Avatar
yes.
the idea to sound deadening is to reduce external noise. in audio, the idea is to reduce unwanted noise from intruding on the wanted noise. in your case, you're just skipping the 'audio' portion.
Lav (04-13-2022)
Old 04-13-2022, 09:39 PM   #22
Lav
Drives: Frs
yes.
Ironically, after I added some cheap Peel and Seal to these places I got into audio. Probably not going to go all out in my car but I wish I had just added foam and vinyl while i was in there. I'm gonna upgrade the resonator on my TRD catback and see if i can at least hear the bass in my music at reasonable volume and go from there before I spend 20+ hours tearing my interior out again.
EDIT: resonator barely did anything. There is a measureable difference using a phone app, but its not nearly enough. https://www.ft86club.com/forums/show...6&postcount=35 for more detailed updates
The Following User Says Thank You to Lav For This Useful Post:
soundman98 (04-13-2022)
Rust Proofing VOSS CANADA 13 10-19-2018 05:09 PM
Rust proofing? rip curl CANADA 17 06-20-2014 01:40 AM
Sound proofing doors Garstang Scion FR-S / Toyota 86 GT86 General Forum 7 10-28-2013 10:04 AM
Rust-Proofing Gunk Taro CANADA 4 10-10-2013 07:57 PM
BRZ limited has factory installed sound proofing ebgs500e BRZ First-Gen (2012+) — General Topics 36 05-27-2013 09:01 AM
