Old 04-18-2021, 11:38 AM   #15
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Originally Posted by doug1234 View Post
Thanks for advice. I'm going to flip the tires and ask the shop to put as much negative camber up to -3.5 front and -3 rear. I'm not sure if my camber plates can get to -3.5 maybe I can get -3.
Sent from my Pixel 2 XL using Tapatalk
Aside from the tire wear how is the handling balance?
Old 04-18-2021, 11:42 AM   #16
jflogerzi
jflogerzi's Avatar
Originally Posted by ZDan View Post
-2.8, just from lowering 1.25" (stock/factory LCAs). Rear camber isn't as important anyway, anything from -2 to -3 I wouldn't worry about it if you don't have adjustability.
I have some basic spc lower control arms.
2013 Series 10 FRS #553
Old 04-18-2021, 01:59 PM   #17
strat61caster
strat61caster's Avatar
Originally Posted by Petah78 View Post
With front camber @ 3.5, what is tire wear like for a mostly street driven car with 2 to 3 days of track a year?
Not great, you'll have to compromise somewhere or at only 2-3 events per year maybe adjusting front between Street/track specs could pan out.
https://photos.app.goo.gl/raGSjKQ6Bx9amELP9
ineedyourdiddly
Petah78 (04-19-2021)
Old 04-18-2021, 10:08 PM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
I only did 4 events last year, and ran my street tires on day one of each event. With 4 track days on my street tires (245/40-17 Conti ECS) and ~5000 street miles, all at -3.5 front camber, I have even wear across the treads. I did rotate between each track event.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
jflogerzi (04-18-2021), Petah78 (04-19-2021)
Old 04-18-2021, 10:32 PM   #19
jflogerzi
jflogerzi's Avatar
Be aware not all tires are able to rotate in a front to back opposite sides
Old 04-18-2021, 10:36 PM   #20
strat61caster
I got about 15k miles out of my firestones but they were probably due to be replaced at 10k miles and were sketchy as fuck at the end, alignment varied throughout.
Big change if you're used to getting 60k miles out of your daily tires... It's all perspective.
ineedyourdiddly
Old 04-19-2021, 07:42 AM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
Hopefully you're not staggered, so swapping front/rear should be no problem.
As for left/right, directional tires *can* be driven in the "wrong" direction without issue. I've done it many times. Tests have shown that running directional tires backwards pretty much doesn't make any difference even in standing water. From what I've read a lot of times the directional pattern is more about noise than actual water-handling or hydroplaning resistance.
That said, for *street* usage rotating front/back is fine. However for multiple track days at the same track, you'll want to do the normal rwd tire rotation pattern (or any pattern really that ensures each tire winds up at each corner of the car on a regular basis).
jflogerzi (04-19-2021)
How does my tire wear look? R_E_L Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2018 07:34 AM
tire wear oppiee Tracking / Autocross / HPDE / Drifting 9 08-29-2017 12:55 PM
Tire Wear? Flo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-10-2017 03:19 PM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 11:31 AM
Let's Discuss Tire Wear SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-14-2014 11:35 PM
