Old 01-07-2021, 02:14 PM   #15
spike021
spike021's Avatar
Originally Posted by JCW 86 View Post
If you're looking for another option, you should check out Block8head. He makes a double and triple pod setup that drops into the defroster vent.
https://www.block8head.com/
Personally, I don't like his triple setup since it seems too large and would run the double setup with an ATI AC vent pod to run three gauges.
The Block8head single pod is what I went with.
Two issues though:
* order to delivery was around 3 months and if you go on his FB page, there are people who have been waiting even longer who have to poke and prod him to remind him of their order (typical for one-man production shops like this)
* the hole access for the cables wasn't large enough for mine and caused the cables to keep hitting the interior vent tube (not sure what else to call it) and the only way to make the cables fit without getting squashed was to enlarge the access hole ourselves. _Maybe_ fancier routing would've helped, but the way we did it it just wouldn't work otherwise.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 2 Users Say Thank You to spike021 For This Useful Post:
JCW 86 (01-07-2021), JesseG (01-09-2021)
Old 01-07-2021, 02:26 PM   #16
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
As others have said, those tabs are not designed to detach from the a-pillar. So if you do remove them, you're never getting them back on.
Also, my opinion is that if this isn't a racecar that you're stripping down, removing safety features that are there to protect you from serious injury or death in case of an accident has never made sense to me. When you build a track car, sure you're removing these things, but you're also adding other measures to compensate for this (roll cages, 5-point harness, helmets, etc). Just because it isn't a daily doesn't mean you should take away your protection simply for the sake of aesthetics. Just because you're a safe and smart driver doesn't mean someone else won't plow into you anyway.
Plan for the worst-case scenario and keep the safety features in tact. Other alternatives are better suited to your situation. My $0.02.
sharpsicle is offline   Reply With Quote
The Following 4 Users Say Thank You to sharpsicle For This Useful Post:
JesseG (01-09-2021), soundman98 (01-07-2021), spike021 (01-08-2021), x808drifter (01-08-2021)
Old 01-08-2021, 11:56 AM   #17
MaverickMonk
Drives: 13 BRZ Limited
While I like keeping all my safety features personally, if its "wrong" to remove them its just as bad an idea to own a car that doesn't have them. If its ok to drive a car from <2010, which most people do (the avg car is 11 years old in the US) then its really up to you. A BRZ with no side curtains is still a heck of a lot safer than an NC Miata. Nevermind an RSX, Integra, <8th gen civic, etc.
MaverickMonk is offline   Reply With Quote
Old 01-08-2021, 04:51 PM   #18
JD001
JD001's Avatar
Drives: Subaru BRZ
nnnnooooOOOOoooo
Further dramatisation..
The Following 3 Users Say Thank You to JD001 For This Useful Post:
JesseG (01-09-2021), NoHaveMSG (01-08-2021), spike021 (01-08-2021)
Old 01-08-2021, 06:49 PM   #19
sharpsicle
sharpsicle's Avatar
And a BRZ with side curtains is safer than all those. Wait, you already have that! Awesome!
That logic still doesn't hold well, since you have to compare what you're doing to outdated technology in the first place. Seriously, reconsider giving up your safety features just to put in gauge pods.....
JesseG (01-09-2021), NoHaveMSG (01-08-2021), spike021 (01-08-2021), x808drifter (01-08-2021)
Old 01-08-2021, 10:08 PM   #20
soundman98
ProCrastinationConsultant
soundman98's Avatar
i feel sorry for who's going to end up buying the car once your done with it, expecting all the pieces to be there when someone ignores their stop sign.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
Old 01-08-2021, 10:30 PM   #21
spike021
spike021's Avatar
Either that or there'll be a much similar moment for OP where the one time they actually need it, it's no longer there...
(yes yes 1 in a million or whatever, but you never know)
Old 01-08-2021, 10:48 PM   #22
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
And now this is on the internet and if a new owner gets injured because of it, guess whos liable.
Chance is slim, but not 0.
Old 02-15-2022, 12:33 PM   #23
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
This looks really nice, does it mess with the functionality of the vents?
I'm considering a double pods.
GPhilly is offline   Reply With Quote
Removing A-Pillar completely (green plastic retainer question) Suparu Cosmetic Modification (Interior/Exterior/Lighting) 4 03-13-2020 06:23 PM
How do you remove the C-Pillar? lupindub Scion FR-S / Toyota 86 GT86 General Forum 15 09-20-2015 11:23 AM
Pillar Removal? kmbkk Electronics | Audio | NAV | Infotainment 2 07-12-2015 12:55 PM
Almost Touching... Pillar!!! Choco BRZ First-Gen (2012+) — General Topics 26 06-26-2015 05:17 PM
C-Pillar Airbags rlpaul Cosmetic Modification (Interior/Exterior/Lighting) 1 05-09-2015 02:19 AM
