Old 02-04-2021, 01:17 PM   #15
ninjan00dles
Drives: 2015 FRS
Another option would be to use a DSM / EVO 1-3 / JDM Mitsubishi RVR 4G63. There are a few "bolt on" RWD transmission options for that swap (Dodge D50 / Mighty Max).
The Evo VIII and Evo IX transmissions are flipped and I don't recall them ever being used in a RWD form from the factory.
https://projectzerog.com/transmissions.shtml
ninjan00dles is offline   Reply With Quote
Old 02-04-2021, 02:52 PM   #16
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by wparsons View Post
I was questioning why the specific BMW one, and not another option.
Because DCT (Dual Clutch Transmission)... and it's really the only decently price DCT option on the market currently.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
wparsons (02-05-2021)
Old 02-04-2021, 07:32 PM   #17
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by Xero-Limit View Post
It wasn't the broken exhaust studs, stripped coolant necks, seized turbo studs, broken transfer cases, walking cranks, or yearly $5,000 transmissions?
Third gear did grind(slighty), never bothered to fix it before I sold it.
Clutch job took two long days on jack stands.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Xero-Limit (02-06-2021)
Old 10-10-2022, 12:48 AM   #18
Sonic86
Sonic86's Avatar
Drives: 2017 Toyota 86 MT White Drift Spec
Hey fellas.
I got a stupid question.
Is there ANY possibility of connecting (somehow) together 4G63 or 4g69 engine and fr-s manual tranny.
I’m getting crazy but really need it.
Sonic86 is offline   Reply With Quote
Old 10-10-2022, 01:56 AM   #19
soundman98
ProCrastinationConsultant
soundman98's Avatar
would definitely need a custom trans adapter spacer, likely also need to convert the engines output shaft to the trans' input shaft pattern.
considering no one else is putting the 4g64 in with the oem trans, it's going to require a machine shop and a large wallet.
Old 10-10-2022, 12:18 PM   #20
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Soundman means using a custom flywheel with a custom trans adapter. Your best bet is ditching the stock transmission for something stronger and that has aftermarket support, as there are already RWD adapter kits for common T56 transmissions.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
soundman98 (10-11-2022)
FRS 4.8 LS swap kurty85 Engine Swaps 207 03-03-2023 12:48 PM
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
