Old 11-17-2020, 01:21 PM   #15
Originally Posted by Toyota. View Post
No work done. To the best of my knowledge it's completely stock. Good to hear that it's more than likely a starter/solenoid issue. Might try tapping the solenoid after I get off work and see if that does anything.
Check all your connections again first. Take the cables off and clean the posts and cable ends then put back on really tight.
Clicks usually mean not enough power so start there before beating on the starter.
As you said in the other thread (see now why two sucks) if it is still under warranty let them take care of it!
p1l0t (11-22-2020)
Old 11-17-2020, 01:22 PM   #16
It's very unlikely that is the case. If it's under warranty then that's a perfectly valid reason to go to a dealership. Much more likely something is loose or a fuse/relay is bad. Perhaps a sensor
In the other thread he says he is just getting clicks so connection is the probable cause.
Old 11-17-2020, 01:24 PM   #17
Ashikabi
Ashikabi's Avatar
Indeed. Probably the first thing to check anyways. You'd think that would have been "fixed" when he changed batteries though
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (11-17-2020)
Old 11-17-2020, 01:26 PM   #18
Toyota.
Drives: (2017) Toyota 86 / 860 / Halo White
Gonna delete the other thread. Appreciate the help brother. I'll check those connections.
Toyota. is offline   Reply With Quote
Old 11-17-2020, 01:28 PM   #19
Not if the cable ends were dirty or not tight enough. I have had what looked like perfect clamps and posts that would not make a full connection until cleaned and had the living crap twisted out of them.
The first thing to check is always battery power. Loose connections mean nothing if there is no power in the battery!
Old 11-17-2020, 01:29 PM   #20
You can't delete but if you ask real nice a Mod may combine them for you.
Old 11-17-2020, 01:33 PM   #21
Toyota.
I unhooked the battery multiple times. Everything inside the engine bay looks flawless. Part of the reason I bought the car was because it was so clean. Crazy how it goes from zero issues for an entire month to being dead to rights after parking it over night. Even with the battery connected, and the dash display on. I can't turn on headlights, lights inside the car, it keeps telling me the trunk is open even when it's not. It's like all the electrical components got fried. Maybe a faulty fuse box???
Gonna use this thread as the main one. Couldn't figure out how to delete the identical thread located in the GT86 Gen 2 subforum.
Old 11-17-2020, 01:35 PM   #22
Toyota.
Dear Mod, please help. I'm losing my mind
Old 11-17-2020, 01:48 PM   #23
MJones_RB
MJones_RB's Avatar
If you bypass the key (bridge the starter) does it turn over? If not then there's an issue with the wiring to the starter. If it does, then the ignition wiring is at fault. Good luck!
MJones_RB is offline   Reply With Quote
Old 11-17-2020, 01:52 PM   #24
ls1ac
ls1ac's Avatar
Problem one
To me it sounds like something drained the battery.
Problem two
Not getting enough voltage/energy to the starter.
Get a cheep volt meter and get a friend to help you learn to use it.
1)Check voltage at the battery. Both static and while trying to start.
2) Check voltage down the line to the starter. Again both static and while trying to start.
A good chance to learn both about the car and how to trouble shoot a problem.
Old 11-17-2020, 02:03 PM   #25
Toyota.
Gonna test this after I get off work. Thank you!
Old 11-17-2020, 02:04 PM   #26
Toyota.
Originally Posted by ls1ac View Post
Problem one
Problem two
Will also check this as well. Thank you brother!
Old 11-17-2020, 02:06 PM   #27
Toyota.
Also, just remembered. The break pedal seems off. Like it won't fully depress. Not sure if this is associated.
Old 11-17-2020, 02:10 PM   #28
OK so we have eliminated battery and battery connections as an issue. Now make sure your fuse block is tightly screwed down and the ground cable to the bellhousing is tight.
Passenger side black wire with bolt.
MJones_RB (11-17-2020)
LED Changed Dual Climate A/C Start Stop Button 2017 LCD Cluster Traction Controls! JNuman85 Interior Parts (Incl. Lighting) 0 04-03-2020 04:01 PM
Help! Is there anyway to change the 2017 cluster start up image? slashlee DIY (Do-It-Yourself) Guides 2 11-17-2018 05:36 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
