Old 09-28-2020, 08:17 PM   #15
Pat
Pat's Avatar
Drives: 2023 BRZ
I think depending on cost my next setup should be the lighter version of that.
Sent from my Pixel 4a using Tapatalk
Old 09-29-2020, 06:51 PM   #16
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Originally Posted by DarkPira7e View Post
I 100% agree with you. While I've had to replace them on a couple previous cars, it was due to them just having been driven hard and who knows how the previous owners treated them as well, I certainly drive my cars hard so I know it's my fault when something breaks.
Regardless of the past, these cars have a penchant for chewing up the TOB. Each platform has unique needs and stressors - for older BMWs, it's the expansion tank and cooling system. Why would anyone think a clutch driven fan or expansion tank is a wear item? You will, when the car overheats because your fan grenaded and took out the rad.
Or a more obvious example - why would headlight brackets be a wear item? Well ask anyone who has owned an NA Miata. When their headlight keeps going down randomly, they'll have torn that thing out and replaced the whole assembly.
I know my point likely falls on deaf ears, but understanding the strengths and weaknesses of the platform is part of the fun, no? Unless your platform is the RX8 and the weakness is the engine.
To me, you’re lumping poor engineering/ design failure with Wear Items.
Everything will fail eventually. But let the rust come first. 🇨🇦
Muskoka800 is offline   Reply With Quote
Old 10-01-2020, 08:12 PM   #17
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Just buy the new bearing. It’ll last with the upgraded grease. Just make sure it has the white dot.
Old 10-01-2020, 08:21 PM   #18
ermax
ermax's Avatar
I have the new one and it’s about 2 years old and starting to die again. That Tilton rig is looking attractive.
Old 10-01-2020, 09:20 PM   #19
Irace86.2.0
Two years? How many miles a year are you driving? It had the white dot?
Old 10-02-2020, 12:42 AM   #20
My "updated" OEM bearings were going out regularly too.
OS Giken bearing has been in for quite a while now...
MJones_RB (01-26-2021)
Old 10-02-2020, 12:52 AM   #21
DarkSunrise
DarkSunrise's Avatar
There’s some discussion out there that it might be the stock clutch fork flexing that’s putting unintended loads on the TOB and causing them to die early. Has anyone run into issues with the updated TOB and a forged clutch fork used together?
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
smg1138 (01-20-2021)
Old 10-11-2020, 10:12 AM   #22
Muskoka800
Thanks for the input All.
Winters coming and I’ll likely put her into hibernation next weekend.
I’ll have months to research/source parts and tools for a Spring project.
Only ~65,000 kl. on the car but may just upgrade the fork, pivot and clutch while in there.
Has anyone used the transmission lift adapter available for a floor jack? About CA$80 at Princess Auto.
Old 10-20-2020, 12:35 PM   #23
Pat
Pat's Avatar
Drives: 2023 BRZ
Does anyone have experience with the Sachs bearing? A friend of mine uses them and says they work great. They area apparently much heavier and better built than any of the OEM versions.
Old 10-20-2020, 01:28 PM   #24
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Money Shift Racing made a hydraulic TOB conversion at one point. Maybe you could contact them?
https://moneyshiftracing.myshopify.c...12460041371749
Old 10-20-2020, 03:16 PM   #25
discontinued afaik.
thatfilipinoguy (10-21-2020)
Old 10-20-2020, 09:56 PM   #26
soundman98
ProCrastinationConsultant
soundman98's Avatar
discontinued afaik.
dangit. it was on my "while i've got the trans out" list that had another 20k miles before it was due...
Old 10-21-2020, 12:58 AM   #27
My understanding is it was discontinued due to a lot of failures.
soundman98 (10-21-2020), thatfilipinoguy (10-21-2020)
Old 10-21-2020, 01:34 AM   #28
soundman98
soundman98's Avatar
I see. I assumed it had been discontinued due to a lack of buyers
Hip replacement and the BRZ g e BRZ First-Gen (2012+) — General Topics 10 07-06-2018 07:12 AM
Replacement Key 86 South Africa AFRICA 7 09-19-2016 04:58 PM
Replacement fun? Mooseknuckle44 Scion FR-S / Toyota 86 GT86 General Forum 44 05-01-2014 12:46 PM
TPSM replacement nabil_frs CANADA 4 04-27-2013 12:58 PM
TPSM replacement nabil_frs Issues | Warranty | Recalls / TSB 2 04-26-2013 10:57 PM
