Old 09-01-2020, 02:16 PM   #15
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by DarkPira7e View Post
Do you have datalogs to support this? I actively monitored my temps with both and didn't see a difference. Granted, I only got to drive my car mostly between 45f and -15f.
Perhaps at high summer temperatures, there's a difference. This is the first I've heard of this though, why would the temperature differ so much?
As the ambient temperature gets a bit cooler I can certainly take a few logs before and after the next oil change if I remember. I just notice the average difference on the OFT display when I drive around in the spring and fall.
Typical ambient temperatures are 50f-70f when I switch over.
As for why this would happen, higher viscosity means the oil molecules like to stick together more. This means that more energy goes into making them slide over each other, resulting in greater heat contained within the oil, assuming all other conditions are equal.
Last edited by Spuds; 09-01-2020 at 02:23 PM. Reason: Forgot to answer the other question. And I'm only doing one oil change this fall lol.
DarkPira7e (09-01-2020), JesseG (09-01-2020)
Old 09-01-2020, 02:18 PM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
As the ambient temperature gets a bit cooler I can certainly take a few logs before and after oil changes if I remember. I just notice the average difference on the OFT display when I drive around in the spring and fall.
So strange, I wouldn't think there'd be such a strong correlation. I want to test this with my car when it is back together so I can get my own datalogs, too!
Thank you for sharing a contrasting observation, it makes things a lot more fun, rather than people just nodding and hitting "Thanks!"
DarkPira7e is online now   Reply With Quote
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
JesseG (09-01-2020), Spuds (09-01-2020)
Old 09-01-2020, 02:27 PM   #17
Spuds
The Dictater
Spuds's Avatar
It would also be pretty interesting if we got different results, possibly based on FI vs NA.
The Following User Says Thank You to Spuds For This Useful Post:
JesseG (09-01-2020)
Old 09-01-2020, 06:38 PM   #18
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Lots of great feedback, thanks all! Spuds you’re right I should have made a poll.
JesseG is offline   Reply With Quote
The Following User Says Thank You to JesseG For This Useful Post:
Spuds (09-01-2020)
Old 09-01-2020, 06:41 PM   #19
JesseG
JesseG's Avatar
Originally Posted by pope View Post
5w30
I'm fine with sacrificing a fraction of a percent of efficiency for a fraction of a percent better hot protection and wider availability. (Summer only car, so 0w vs 5w is irrelevant).
This is something I was curious about, engine protection in hotter climates. It gets hot as balls in Texas. I usually drive conservatively and don’t track my car. In the hottest part of the summer with the AC on my car feels very slow, and I don’t wring it out.
Old 09-01-2020, 06:47 PM   #20
JesseG
JesseG's Avatar
Should have just made a poll.
Mobil 1, 5w30 in the summer, 0w20 in the winter, usually changed in April and October.
My car is NA. I notice a difference between the two weights, but it's probably just in my head.
There is a lot of voodoo and mystery whenever engine oil is brought up. I wouldn’t be surprised if you do feel a difference, even if it’s a placebo effect. It’s also good to see evidence of oil temps and wear indicators to decide on what oil to use.
Old 09-01-2020, 06:49 PM   #21
JesseG
JesseG's Avatar
I ran 0w-20 and 5w-30 and saw no difference in temperatures on my turbo build, I plan on running a 5w-30 on my new engine to keep oil pressure up a little higher on cold starts and during high temperature operation with the turbo.I change my oil every few thousand miles to check on its condition and see if I need to make adjustments / send it in for analysis with Blackstone.
I would not do that under normal circumstances- if my car was not turbo, I would run a 0w-20 and change the oil every 5k, unless something felt strange.
It seems like really good insurance to run at least 5W30 in a turbo FA20. Higher temps are guaranteed. You also get that awesome woosh of power.
Old 09-01-2020, 06:52 PM   #22
JesseG
JesseG's Avatar
Originally Posted by Grady View Post
0w20 stock,
5w30 when I installed the turbo,
Switched to 0W40 last 100 deg track day, probably not necessary, still did not see oil temp over 250.
There is only 1 correct answer when someone asks what type of oil to use.... “New” is the correct answer.
I didn’t even know there was 0W40. It has to be more expensive. And yes I agree completely, the best insurance is frequent oil changes.
Old 09-01-2020, 06:55 PM   #23
JesseG
JesseG's Avatar
Originally Posted by DarkSunrise View Post
I typically use Mobil 1 0w30 for the summer since it includes track and canyon time. For the winter I used to switch back to 0w20, but now that I live in a temperate climate, I don't bother.
If I was only street driving the car, I'd use the recommended 0w20 and not even worry about it.
I’m thinking I will just stick with 0W20. I don’t track my car so oil temps probably don’t get high enough to worry about it. I think the comment from the Mighty Car Mods video got me a little spooked.
Old 09-01-2020, 08:10 PM   #24
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
It’s like 25 bucks for an oil analysis. Do one at your next oil change. Do it at 5k or above. If it’s good you know, if it’s bad change earlier or change oils.
Ernest72 is offline   Reply With Quote
The Following User Says Thank You to Ernest72 For This Useful Post:
JesseG (09-01-2020)
Old 09-01-2020, 09:25 PM   #25
JesseG
JesseG's Avatar
I’m gonna do just that! I’ve never sent oil in for analysis but I plan on keeping the FR-S for a while. I think I will set it aside for my daughter. And pick up a 2020 86/BRZ or a 2nd gen. Would it be insane to have basically two of the same car?!
Oh and I’m at about 29,000 miles.
Old 09-02-2020, 02:07 AM   #26
DarkSunrise
DarkSunrise's Avatar
I just watched that video. If you're in a hot climate or drive you car hard (track/canyons/etc.) and it concerns you, you can safely bump up to a 30 weight. That's actually recommended by the manual for high speed operation or extreme load conditions. Toyota South Africa specs a 5w30 given their high temps and the Japanese Subaru manual apparently specs a 0w30, multiple 5w30s and even a 5w40 (in addition to some 0w20 oils).
Lot of good information in this thread:
https://www.ft86club.com/forums/show...t=28477&page=4
I still don't think it's necessary unless you're doing track days or lots of backroad driving, but you should definitely consider a 30 weight if it would give you some peace of mind. As mentioned I've been using M1 0w30 with no issues.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
JesseG (09-03-2020), Spuds (09-02-2020)
Old 09-02-2020, 03:35 AM   #27
Purist
Purist's Avatar
Drives: Subaru BRZ
Penrite Enviro GF5 plus 5W30. E85 compatible. Someone (possibly the Penrite tech) told me the 0w20 has to do with emissions and not a mechanical requirement for such a thin oil.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
JesseG (09-03-2020)
Old 09-03-2020, 12:14 AM   #28
JesseG
JesseG's Avatar
It would be nice peace of mind to bump up to a 0W30. And it gets hot here, so even if I’m not driving too hard the engine is still under more stress. I honestly didn’t even know 0W30 and 40 existed.
Forced Induction Oil Viscosity Towelly AUSTRALIA 7 03-05-2019 12:35 AM
Oil viscosity in warm climate Sharpilot Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 09-13-2018 07:42 AM
Extremely Hot Weather - Engine Oil Viscosity Guru86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 11-22-2017 10:07 AM
Engine oil viscosity for hot climate redburn86 Engine, Exhaust, Transmission 6 08-10-2014 08:11 AM
**Best viscosity for frs and brz** 21_nola_05 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 05-29-2014 11:10 AM
