Old 07-29-2020, 07:55 PM   #15
jflogerzi
jflogerzi's Avatar
Originally Posted by 86TOYO2k17 View Post
Took a minute to align properly. But has better than OEM fitment, perfect lines/gapping by fenders.
Do you have oe hood prop or aftermarket hood dampers?
2013 Series 10 FRS #553
Old 07-29-2020, 07:58 PM   #16
86TOYO2k17
Drives: 2017 toyota 86
OE. Only thing different besides hood is hood pins. Still use center latch as well. Hood pins are super easy to install, has a perfect alignment hole on underside. But drilling into a brand new 1k$ hood is nerve racking .
Old 01-27-2023, 11:05 AM   #17
B T
@86TOYO2k17 How much lower is that center intake vent than the stock hood? Thinking about getting that model but it may interfere with the edelbrock supercharger.
B T is offline   Reply With Quote
Old 01-29-2023, 05:14 AM   #18
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Last Activity: 11-11-2022 04:21 PM
Even worse the last post before you necroed it was in 2020.
Or IDK message them directly.
Old 01-29-2023, 03:15 PM   #19
B T
That's really helpful
If I had been able to find the answer I wouldn't have been asking. There's no record of other Edelbrock guys running that hood, but that doesn't necessarily mean it won't fit. Why answer if your post is worthless?
The Following User Says Thank You to B T For This Useful Post:
alphasaur (02-06-2023)
Old 01-30-2023, 03:10 AM   #20
x808drifter
LMGTFY
To let you know you're a dumbass.
Search implies what I found. IE they haven't been here for months.
The smart thing to do would have been to msg them directly as I said.
Pretty helpful if you use your head.
17+ engine oil temps tfp BRZ First-Gen (2012+) — General Topics 95 11-14-2019 08:45 PM
Engine Oil Temps after Oil Cooler ryoma Engine, Exhaust, Transmission 31 03-23-2016 09:21 PM
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 02:50 PM
Boxer engine and temps SlinkyAvalanche Engine, Exhaust, Transmission 9 03-27-2014 03:00 PM
Reducing engine compartment temps mike_ekim1024 Engine, Exhaust, Transmission 1 12-11-2013 02:57 AM
