#15 | |
You said it was a year between the work and the failure but how many miles was it? You have established it is a rod or is that still just a guess?
#16 |
Drives: 2013 Scion frs
There were 11000km and it was a rod as diagnosed by the shop.
Sent from my SM-G960W using Tapatalk |
#17 |
Not a spun bearing?
#18 |
#19 |
Panda Trueno
Drives: No twin now.
I'd register that car in another state before I did that. Lol. Montana looks nice. At least take a little bit of money away from California.
#20 |
A thrown rod can be attributed to many other things such as an overrev downshift and is actually a pretty rare (not unheard of but rare) result of the botched seal job. A spun bearing is almost always the result and is much cleaner to tie into the rest of the failures. All in all it just takes one more argument away from the dealer if it is the bearing.
#21 |
Drives: '13 Whiteout
I had my clutch go out on the freeway in the middle of traffic due to the fork pivot not secured properly during the recall. To add insult to injury the rods started knocking just before that. I'm having someone else do the work. My trust in dealers is 0% however they DO talk a good game "Oh yeah! We've done hundreds of these with no issues".....
#22 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
You're having an independent shop do the J02 recall? How is that documented and will the CA DMV accept documentation from a non-dealer for the work?
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#23 |
No! a dealer did the recall and totally destroyed my car. Didn't tighten the pivot at the clutch fork and car broke in the MIDDLE of the freeway in LA at rush hour And that was just after the rods started knocking due to the sealant clogging the oil pump and tubes. Total Fu#k story.
#24 | |
Oh ok - I misunderstood (or didn't read the whole story). So you're having the repairs caused by the dealer doing the recall done by someone else. Did you go back to the dealer to complain? Are they going to accept any responsibility? That sucks, man - sorry to hear that.
#25 | |
#26 | |
#27 | |
#28 | |
Well that isn't our problem you'll need to try to get an UBER. A 100 dollar bill told the driver to let me ride in the truck. |
| Tags |
| j02, recall, turbo, valve spring recall |
| Results of the Valve Spring Recall Work | Magoo | Issues | Warranty | Recalls / TSB | 241 | 01-13-2022 02:38 PM |
| Valve spring recall - where did you get it done? satisfied with the work? | fiveoneoh | Northern California | 103 | 09-25-2020 02:10 PM |
| Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
| valve spring recall/ additional work performed when engine is out | swfrs | Issues | Warranty | Recalls / TSB | 172 | 07-31-2019 12:10 AM |
| Valve Spring Recall- Heffner Toyota Kitchener | TYinhouse | CANADA | 29 | 07-19-2019 06:12 PM |
