CANADA Canada
Old 02-25-2019, 01:24 PM   #1
TYinhouse
Drives: Scion FRS Firestorm MT
Valve Spring Recall- Heffner Toyota Kitchener
I scheduled an appointment with Heffner today for the valve spring recall. have any you of you guys gone done it? Service rep suggested changing the clutch at the same time with a cost around $750-$850 (mileage = 114K), what do you guys think?
also, has anyone call toyota roadside service for vichcle pick up instead of driving to the dealership yourself?
TYinhouse is offline   Reply With Quote
Old 02-25-2019, 02:40 PM   #2
Turbo
Drives: FR-S Turbo
Did they give you a break down on that $750-850 cost? If not, I would request they do so in writing (maybe attack it a bit informal via e-mail).
A clutch replacement should be 15 minutes labour tops with the engine already out of the car. A flywheel and clutch 30 minutes tops.
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
wparsons (02-26-2019)
Old 02-25-2019, 03:47 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That's what I would expect for a clutch job under normal circumstances. With the engine already out that's highway robbery.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Turbo (02-25-2019), wparsons (02-26-2019)
Old 02-25-2019, 07:13 PM   #4
NyX_Nick
Drives: 2013 WRB BRZ Stock, 1991 Toyota MR2
$750 for a clutch job is normal rate. If they do it during the recall it should cost no more than maybe $400, and that's including parts. If you're replacing the flywheel too, then $600.
The engine has to come out to do the recall, anyways, changing the clutch while the engine is out should take maybe 10-15 minutes on top of the time of the recall work. At $750 the dealership just thinks you're gullible
NyX_Nick is offline   Reply With Quote
The Following 2 Users Say Thank You to NyX_Nick For This Useful Post:
Old 02-26-2019, 10:32 AM   #5
wparsons
wparsons's Avatar
Clutch and flywheel parts should be like $400ish, add 30 minutes labour and there's no way you're hitting $750.
flickr
Old 02-27-2019, 11:22 AM   #6
TYinhouse
Thanks for the feedback guys.
Old 04-12-2019, 05:06 PM   #7
Timmehh123
Drives: sil'13Fr-S-Inv N1,K&N,18FASTHayaku
Hey bud, I live in Waterloo as well. I have a '13 Fr-S that's on that list too, but haven't scheduled my appointment at Heffner yet. I have been hearing a WHOLE LOT of horror stories lately about Toyota techs botching this job and then Toyota not paying for repair costs.
Did you get your valve springs repaired? Were you provided with a rental car? and how is your car driving now? any response at all would be greatly appreciated!
Timmehh123 is offline   Reply With Quote
The Following User Says Thank You to Timmehh123 For This Useful Post:
Turbo (04-12-2019)
Old 04-19-2019, 08:37 AM   #8
crash_can
Drives: BLACK FRS
I will post about my experience at Hefner and the valve spring repair
Feb 14 Hefner Finished my recall repair work
Feb 16 I had to tow my car in at my expensive because the motor was knocking
March 18 after multiple called and emails to Toyota Corp they Finally agreed to replace the short block and gave me a rental car until my car was done but parts where on back order
April 9 my car was returned to me with the new short block
It seams to be running fine so far I have about 1000km so far
I did ask I have 90day warranty on the repair
crash_can is offline   Reply With Quote
Old 04-19-2019, 01:31 PM   #9
Timmehh123
Thanks for your response. Unfortunately I guess my gut instinct could be right on this one, based on so many of these reports and now yours being so close to home for me.
How was yours running before the valve spring repair and at how many kms?
In hindsight, would you have taken it in at all or maybe ignored it?
And it looks like maybe you were approx 1 month with not even a rental car, and I'm sure a lot of your calls with Toyota were angry ones... are you pretty pissed at Toyota right now or do you feel like they have compensated you adequately?
Old 04-20-2019, 07:21 AM   #10
crash_can
Drives: BLACK FRS
I would have waited a few months to get the repair, I had 150,000km on her, the car was running fine before the recall
Toyota Corp Canada sent pictures and a report to Toyota Japan and they made the finial decision to get it repaired
It was 3 very stressful weeks not knowing if the repair would be done
I’m happy with the repair once Hefner got approval from Toyota Corp
Because it a Subaru motor the motor tech at Toyota don’t see them often enough, I’m sure if it was a corolla motor there would be no problems
Positive spin is I basically have a brand new motor
Old 04-20-2019, 10:14 AM   #11
Timmehh123
Glad to hear that you have a good feeling about this in the end! After so much stress, you deserve some relief.
So true about the Corolla motor... just another reason why a 2J or 2J variant would have been a much better engine option in these cars. Thanks for the update!
Old 04-20-2019, 03:48 PM   #12
Turbo
Drives: FR-S Turbo
You may want to double check consumer protection laws.
There are rules about the minimum warranty they can offer on repairs that use new parts. I believe it's 1yr/12,000km but you will want to check that.
Thank you VERY much for updating your story.
Old 04-20-2019, 09:17 PM   #13
wparsons
wparsons's Avatar
It's not that it's not a Toyota engine... most Toyota techs never see work like this at all. The vast majority of work on Toyota's is brakes/fluid/filters, basically just replacing whole assemblies. I bet this is the first time an engine has been out in some dealerships.
flickr
Old 04-26-2019, 05:08 PM   #14
aimforapex
aimforapex's Avatar
Drives: car
Them Toyota engines are way too reliable to get pulled and disassembled haha. Someone out there with a 1992 corolla and 400k on the motor still running perfectly fine.
aimforapex is offline   Reply With Quote
The Following User Says Thank You to aimforapex For This Useful Post:
wparsons (04-29-2019)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
Valve Spring Recall Dealers AsianStyle Mid-Atlantic 20 05-04-2019 02:43 PM
Valve Spring Recall venturaII New England 13 02-25-2019 07:41 PM
Valve Spring Recall for FI (Turbo or SC) Eazy-V Issues | Warranty | Recalls / TSB 8 01-28-2019 12:56 PM
