Old 07-29-2020, 10:06 AM   #15
Originally Posted by scott.melville View Post
Don't do the recall, the mechanics are not trained to work on Suburu FRS engine, they caused me 7000 in damaged Rod
Sent from my SM-G960W using Tapatalk
BRZs had failure rates at the same level as Toyotas. It wasn't a training issue just a carelessness one. There were even several failures with factory sealed engines because the robots couldn't even get the sealant right.
You said it was a year between the work and the failure but how many miles was it? You have established it is a rod or is that still just a guess?
Old 07-29-2020, 11:05 AM   #16
scott.melville
Drives: 2013 Scion frs
There were 11000km and it was a rod as diagnosed by the shop.
scott.melville is offline   Reply With Quote
Old 07-29-2020, 12:34 PM   #17
Not a spun bearing?
Old 08-06-2020, 09:07 PM   #18
scott.melville
Not a spun bearing?
I have to check to confirm, what difference world it make to my case?
Old 08-06-2020, 09:30 PM   #19
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I'd register that car in another state before I did that. Lol. Montana looks nice. At least take a little bit of money away from California.
The Following User Says Thank You to Summerwolf For This Useful Post:
why? (08-07-2020)
Old 08-07-2020, 07:57 AM   #20
A thrown rod can be attributed to many other things such as an overrev downshift and is actually a pretty rare (not unheard of but rare) result of the botched seal job. A spun bearing is almost always the result and is much cleaner to tie into the rest of the failures. All in all it just takes one more argument away from the dealer if it is the bearing.
Old 08-07-2020, 01:42 PM   #21
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I had my clutch go out on the freeway in the middle of traffic due to the fork pivot not secured properly during the recall. To add insult to injury the rods started knocking just before that. I'm having someone else do the work. My trust in dealers is 0% however they DO talk a good game "Oh yeah! We've done hundreds of these with no issues".....
TommyW is offline   Reply With Quote
Old 08-07-2020, 05:42 PM   #22
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
You're having an independent shop do the J02 recall? How is that documented and will the CA DMV accept documentation from a non-dealer for the work?
shiumai is offline   Reply With Quote
Old 08-07-2020, 07:47 PM   #23
TommyW
TommyW's Avatar
No! a dealer did the recall and totally destroyed my car. Didn't tighten the pivot at the clutch fork and car broke in the MIDDLE of the freeway in LA at rush hour And that was just after the rods started knocking due to the sealant clogging the oil pump and tubes. Total Fu#k story.
Old 08-07-2020, 07:55 PM   #24
shiumai
shiumai's Avatar
Oh ok - I misunderstood (or didn't read the whole story). So you're having the repairs caused by the dealer doing the recall done by someone else. Did you go back to the dealer to complain? Are they going to accept any responsibility?
That sucks, man - sorry to hear that.
The Following User Says Thank You to shiumai For This Useful Post:
TommyW (08-08-2020)
Old 08-08-2020, 11:30 AM   #25
TommyW
TommyW's Avatar
i haven’t heard back yet. I emailed the service manager yesterday
Old 08-08-2020, 12:19 PM   #26
daniloneil8
Originally Posted by Grady View Post
That is the way things are in our “its not my fault” world we live in. There is to much liability on that shop to work on it. Not to mention it is going to add additional man hours to that job that Toyota is not going to pay. If they did work on your car it would probably put their profit down to $0 and triple their liability. Not smart business decision. If you cant not do the work there are a lot of performance shops out there now that can.
False. Tuners and modders tend to ruin whatever they touch. Toyota is correct in not dealing with the hot mess a home brew fool has created.
daniloneil8 is offline   Reply With Quote
Old 08-08-2020, 12:20 PM   #27
daniloneil8
Please tell us in detail how this played out. This is my nightmare, where my car dies in heavy traffic. How did you get out of it ?
Old 08-08-2020, 01:09 PM   #28
TommyW
TommyW's Avatar
I had to wait for a tow truck. A CHP officer came and blocked traffic then helped me push the car to the side of the freeway after a 1\2 hour wait. Then the AAA dispatcher told me I couldn't ride with the tow truck driver due to covid and I asked well so he leaves me on the side of the freeway?
Well that isn't our problem you'll need to try to get an UBER.
A 100 dollar bill told the driver to let me ride in the truck.
j02, recall, turbo, valve spring recall
Results of the Valve Spring Recall Work Magoo Issues | Warranty | Recalls / TSB 241 01-13-2022 02:38 PM
Valve spring recall - where did you get it done? satisfied with the work? fiveoneoh Northern California 103 09-25-2020 02:10 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 07:03 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 12:10 AM
Valve Spring Recall- Heffner Toyota Kitchener TYinhouse CANADA 29 07-19-2019 06:12 PM
