#15 |
Drives: 2017 BRZ w/PP
#16 | |
Because compromise ®
Drives: Red Herring
| The Following 3 Users Say Thank You to Captain Snooze For This Useful Post: |
#17 |
ProCrastinationConsultant
i love how so many people honestly believe that ABS helps a car stop.
it DOES NOT help you stop. it MAINTAINS CONTROL while stopping. it does this by sacrificing stopping distance for control while stopping. it's for grandma's that have no concept of pedal modulation, that just mash the brake harder when things go wrong, instead of re-evaluating the situation and manually releasing the brake a little.
| The Following 4 Users Say Thank You to soundman98 For This Useful Post: | Captain Snooze (07-05-2020), Icecreamtruk (07-13-2020), Jdmjunkie (07-04-2020), Tokay444 (07-04-2020) |
#18 | |
Drives: Miata
With abs and traction control, the throttle and brakes are used like an on/off switch. |
#19 |
i'm of the opinion that threshold braking can be more precise than trying to allow the car to work it out, as the wheels need to first slip for the car to know to work anything out.
#20 |
Drives: BRZ 2017 Pure Red, MT
You can do threshold braking without deactivating abs. If abs is kicking in, that generally means you failed your threshold braking and the wheels were starting to lock-up.
| The Following 5 Users Say Thank You to nico_rsx For This Useful Post: | churchx (07-05-2020), GrandSport (06-12-2023), rice_classic (07-05-2020), soundman98 (07-05-2020), strat61caster (07-13-2020) |
#21 | |
Drives: Miata
I was already trailing off the brakes and keeping the wheel rolling, abs kicked in anyway. |
#22 |
Drives: 2017 BRZ series.yellow
The ABS you find on a regular street car is not meant for racing.
I'm used to racing a car without ABS, I'm hoping on my new BRZ the ABS doesn't give me any problems. |
#23 |
Drives: 2016 Scion FRS
I've always been baffled by the anti-ABS crowd.
You should very rarely be getting into ABS and it may save your butt. Personally, I can push harder and more confidently without having to worry about lockup. You can get into ABS very slightly without ruining your run or your lap and that necessarily isn't the case with lockup. |
#24 |
If you can stop faster with the ABS fuse pulled in a BRZ, I will paypal you 5 dollars.
- Andrew |
| The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#25 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Racecomp Engineering (07-13-2020) |
#26 |
Drives: Track preped NA FRS
If there's a wall in the way, I can stop faster too!
Im going to end up doing an ABS delete at some point, proper stuff tho, removing the whole unit reconnect the lines and add a proportioning valve to the rear line coming out of the MC to adjust bias. But for OP's discussion, I believe the problem is that brake bias switches to the front quite a bit, its a pain to work around but not impossible. You might make something work with different pads front and rear but it might be easier to just add 42lbs of ballast. |
#27 | |
And yes, that includes weekend warriors. imho the brake electronic brake biasing that allow the driver to actually use the brake mid-corner with the wheels unevenly loaded are awesome, I'm not in a hurry to get rid of it. |
| The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
#28 |
Drives: Crapcan
I hadn't tracked my car since last September and it saved me a bunch Saturday. My foot work was quite clumsy.
| Dashboard fuse box - mini fuse removal | airrick | Electronics | Audio | NAV | Infotainment | 0 | 10-25-2019 06:05 PM |
| Removed | createluck | Wheels and Tires | 6 | 02-02-2016 12:37 PM |
| REMOVED | Chimera | Audio/Visual, Electronics, Infotainment, NAV | 1 | 06-28-2014 11:48 AM |
| removed | Fast_Freddy | DIY (Do-It-Yourself) Guides | 11 | 11-02-2013 07:46 PM |
