#16 | |
Drives: 22 BRZ limited
IIRC, 17+ don't need the pedal dance. You just hold the correct button, and achieve the same effect. |
#17 |
TRACKBREAD
#18 | |
Should be Page 101 on the 2017 MY change pdf. Will edit in a sec to include pic. |
#19 |
Drives: Crapcan
Is the EBD interference still active? With the older cars on the long press it has e-diff and EBD interference. Need to trail brake the car into a fast corner to tell if it is acting up.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Yoshoobaroo (06-24-2020) |
#20 | |
The EBD is the brake LSD in the pic above. To answer the question, no. Edit: Unless you have an AT. Then it is still on. |
| The Following User Says Thank You to dragoontwo For This Useful Post: | Yoshoobaroo (06-24-2020) |
#21 | |
Drives: Crapcan
I run a trac box now so I just run pedal dance at the flick of the switch. I am just curious if the long press on the 17+ does this too.
#22 | |
It would appear that I may be mistaken then. I'm going to have to follow that up with a resounding I don't know right now. I'll try to find an answer, if I can. |
| The Following 3 Users Say Thank You to dragoontwo For This Useful Post: |
#23 | |
Drives: Crapcan
![]() If anyone could confirm this I would appreciate it. I know a few people that would be interested in swapping over to this setup as opposed to doing a trac box. Seems like a good intermediate option.
#24 |
Drives: 2013 whiteout fr-s
Wow, Thanks for the wonderful DIY guide. I'm really interested in doing this mod now. Couple of questions about the cluster's lights. What light would turn on when hill assist is activated? For the Track mode, I would assume the VSC Sport light would go on?
| The Following User Says Thank You to haloterence For This Useful Post: | Yoshoobaroo (06-26-2020) |
#25 | |
TRACKBREAD
The 2013-2016 cluster does not have a light for hill start. You’d have to test the hill start on a hill after activating it to confirm that it’s working. Or you can retrofit a facelift cluster, but that’s probably not worth it for just the hill start light. Track mode lights up the same as the old VSC Sport mode. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | haloterence (06-26-2020) |
#26 |
Drives: FR-S Whiteout
Perfect!
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | Yoshoobaroo (06-26-2020) |
#27 |
Just curious: when you pull the pins for 8 and 9, were there wires connected to those pins originally, or were they just empty? If there were wires there, do you just tape them to the side, unused?
Thanks for this! Just ordered my newer VSC module from @417motoringparts |
| The Following User Says Thank You to MJones_RB For This Useful Post: | Yoshoobaroo (06-30-2020) |
#28 | |
TRACKBREAD
I got mine from 417motoring too. They're good, they sent it to me twice cause Fedex is useless and sent it back to them. |
| Review of "Track Mode" on the MY17+ cars | trippinbillies40 | Tracking / Autocross / HPDE / Drifting | 85 | 02-22-2021 09:27 PM |
| FS: Nameless muffled track pipe 2013-2016 | Dave-ROR | Engine, Exhaust, Bolt-Ons | 4 | 05-20-2020 11:27 PM |
| Track mode vs. VSC sport | alex87f | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 10-30-2018 10:47 PM |
| 2017 Track mode on older model | Bobster | Engine, Exhaust, Transmission | 17 | 12-03-2017 10:34 PM |
