Old 06-24-2020, 11:06 AM   #15
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Quoting Chris' post in the DIY as supplemental info
Old 06-24-2020, 11:20 AM   #16
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by Pat View Post
Thanks everyone for contributing to this post. I didn't realize there was SUCH a difference between the early cars and later cars. I normally tell people to do the pedal dance, but may just be alright with them using the track mode in 17+ cars. The video from trippinbillies was helpful, and I know Chris is an excellent driver, as I drove with him regularly when he lived here. I trust his opinion. If I'm competing in a 17+ car I'd still do the pedal dance, but until reaching that level, it probably just doesn't really matter all that much. Thanks again.
IIRC, 17+ don't need the pedal dance. You just hold the correct button, and achieve the same effect.
Old 06-24-2020, 11:50 AM   #17
Yoshoobaroo
TRACKBREAD
Please cite a source for this, i can't find anything corroborating that. all I can find is that pedal dance works the same on 17+ as previous years.
Old 06-24-2020, 12:42 PM   #18
dragoontwo
dragoontwo's Avatar
Should be Page 101 on the 2017 MY change pdf. Will edit in a sec to include pic.
Old 06-24-2020, 01:16 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Is the EBD interference still active? With the older cars on the long press it has e-diff and EBD interference. Need to trail brake the car into a fast corner to tell if it is acting up.
Old 06-24-2020, 01:20 PM   #20
dragoontwo
dragoontwo's Avatar
The EBD is the brake LSD in the pic above. To answer the question, no.
Edit: Unless you have an AT. Then it is still on.
Old 06-24-2020, 01:32 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I notice brake LSD comes on when I hit a curb and get a wheel airborne. The sensation I am talking about is trail braking and having it dump a bunch of bias to the rear.
I run a trac box now so I just run pedal dance at the flick of the switch. I am just curious if the long press on the 17+ does this too.
Old 06-24-2020, 01:58 PM   #22
dragoontwo
dragoontwo's Avatar
It would appear that I may be mistaken then. I'm going to have to follow that up with a resounding I don't know right now. I'll try to find an answer, if I can.
Old 06-24-2020, 04:23 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks
If anyone could confirm this I would appreciate it. I know a few people that would be interested in swapping over to this setup as opposed to doing a trac box. Seems like a good intermediate option.
Old 06-26-2020, 01:10 AM   #24
haloterence
haloterence's Avatar
Drives: 2013 whiteout fr-s
Wow, Thanks for the wonderful DIY guide. I'm really interested in doing this mod now. Couple of questions about the cluster's lights. What light would turn on when hill assist is activated? For the Track mode, I would assume the VSC Sport light would go on?
haloterence is offline   Reply With Quote
Old 06-26-2020, 07:24 AM   #25
Yoshoobaroo
TRACKBREAD
The 2013-2016 cluster does not have a light for hill start. You’d have to test the hill start on a hill after activating it to confirm that it’s working. Or you can retrofit a facelift cluster, but that’s probably not worth it for just the hill start light.
Track mode lights up the same as the old VSC Sport mode.
Old 06-26-2020, 10:24 AM   #26
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Perfect!
Intent > Content
Old 06-30-2020, 02:13 PM   #27
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Just curious: when you pull the pins for 8 and 9, were there wires connected to those pins originally, or were they just empty? If there were wires there, do you just tape them to the side, unused?
Thanks for this! Just ordered my newer VSC module from @417motoringparts
MJones_RB is offline   Reply With Quote
Old 06-30-2020, 02:19 PM   #28
Yoshoobaroo
TRACKBREAD
No wires present, just a rubber plug in the hole.
I got mine from 417motoring too. They're good, they sent it to me twice cause Fedex is useless and sent it back to them.
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 09:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-20-2020 11:27 PM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 10:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
