Old 05-28-2020, 10:35 PM   #15
solidsnake11
Drives: brz
Originally Posted by tomm.brz View Post
weird
did you try disabling any extra features?
also send the log to ecutek support attached with your tune
They will help you figuring out more
They already told me I couldn't run the k24 with the BRZ brain.
It seems to run great besides this 85% throttle thing.
I will see what they say.
Thanks for your help
solidsnake11 is offline   Reply With Quote
Old 05-29-2020, 01:03 AM   #16
tomm.brz
Drives: brz 2017 hksv2
they told me I couldn t flash other regions' calid , what they tell you doesn t matter, they still can help you debugging This or at least try to understand why the fuel cut
The Following User Says Thank You to tomm.brz For This Useful Post:
solidsnake11 (05-29-2020)
Old 05-29-2020, 03:13 AM   #17
tomm.brz
but hey first try disabling launch and flatfoot!
Didn vtec enabled with the same custom maps you did on the cpc output? was sufficient the a01g switch?
Old 05-29-2020, 06:15 AM   #18
solidsnake11
Drives: brz
Yes i used the same maps to operate vtec. I will try that.
Old 05-29-2020, 06:27 AM   #19
tomm.brz
well at least someone that finally confirm USDM racerom patch don t work good
Also, just for more integrity, put X axis on the intake cam you did for Vtec as Engine load as the stock table instead of MAP
and move the activation map you did(can t remember maybe Custom Map N? ) before the cam custom map
Ecu reads them in alphabetically order
but I saw you put some deactivation delay so it s probably already ok,
try anyway to put them in correct order just to avoid strange behaviour
Old 05-29-2020, 07:30 AM   #20
steve99
yes can confirm racerom 9.1 seemed stable very few bugs. Racerom 10,11,12 quite a few strange bugs especially on 2017+ cars and especialy on non european roms ie usa roms.
Old 05-29-2020, 07:40 AM   #21
solidsnake11
Drives: brz
With launch turned off and launch retard map off it has ran flawless. Turning to 8400rpm
Now what?
A01G did the same as A01C with the mystery fuel cut with launch and map enabled.
Old 05-29-2020, 08:29 AM   #22
tomm.brz
now you can ignore the bug, put accelerator trigger for launch a bit higher
and maybe enable launch only on another map on the cruise lever and then switch over to the stable map
or you do debugging with ecutek support if they are willing to
Old 05-29-2020, 09:30 AM   #23
solidsnake11
Drives: brz
The fuel cut only happens in lfa 3.
Last log never went in lfa 3
Old 05-29-2020, 10:43 AM   #24
solidsnake11
Drives: brz
I sent Ecutek an email
Do you think this map could cause it fuel cut.
Boost Target Mode/Gear Limiter
Old 05-29-2020, 10:48 AM   #25
tomm.brz
no, that modifies only the target when you have an ebcs
it won t fuel cut ever
Neither boost limit that you already encountered days ago will cut fuel, it s cut accelerator pedal %
Old 05-29-2020, 10:57 AM   #26
solidsnake11
Drives: brz
This is the reason I asked
Old 05-29-2020, 12:34 PM   #27
tomm.brz
it's sketchy as hell , i see what you mean
i think fuel cut is an error from them and they meant throttle closing
Anyway you set boost limit to 4 bar, it shouldn't trigger
Also it fixes by disabling launch, so i guess it was that
Old 05-29-2020, 01:04 PM   #28
solidsnake11
Drives: brz
Here is my answer from ecutek
That's a little beyond what we normally offer support for, as its well beyond what the software has been designed for.
My only real suggestion would be to check all of the clutch switch wiring etc, there is also a logging parameter for the Clutch Switch that may help you diagnose the cause
Kind Regards
He told me LFA 3 was clutch switch, maybe I'm riding the clutch a little. The clutch switch doesn't show it unless it uses the other switch. It still don't make since why it cuts fuel because its way past the Launch speed. I never had flatfoot enabled.
ABS C1288 - ECU Matching failed MatGO Issues | Warranty | Recalls / TSB 21 05-30-2022 09:19 AM
Rocker arm failed displacedTexan Issues | Warranty | Recalls / TSB 77 08-22-2018 06:16 PM
AC failed under 6 years. wparsons Issues | Warranty | Recalls / TSB 5 05-16-2018 11:08 PM
Hlep. I failed. Shaisters Northwest 14 06-02-2016 10:56 PM
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 06:27 PM
