Old 05-27-2020, 05:35 PM   #1
solidsnake11
Drives: brz
Google has failed me, need help with fuel cut ecutek
Car runs great everywhere except if I stab it from 50% to 100% throttle in the mid rpm range.
solidsnake11 is offline   Reply With Quote
Old 05-27-2020, 07:12 PM   #2
tomm.brz
Drives: brz 2017 hksv2
that s vague description of a problem. does it knock or what? it bogs?
i dont even really remember the whole parts of your frankenbuild, which injectors commanded by PI do you have?
solidsnake11 (05-28-2020)
Old 05-27-2020, 07:29 PM   #3
solidsnake11
Drives: brz
Goes lean and Flat on its face. Everwhere else it runs great. 1050 injectors. If i go slower with the throttle it does fine.
Old 05-27-2020, 07:43 PM   #4
solidsnake11
Drives: brz
I looked at the logs closer and its fuel cut?
6040rpm at 3.04 g/rev
90% throttle and 0 ms fuel
Old 05-27-2020, 11:11 PM   #5
tomm.brz
I have no idea
could you post the entire log?
if you want link me your current tune, maybe I see something off looking at it
Old 05-28-2020, 12:04 AM   #6
solidsnake11
Drives: brz
k24log
3rd hump is the cut
k24-1050port-ls3direct-3barbosch.bin
I think I'm ready to switch to A01G.
I used a custom map to drop timing in launch, before it would not keep the timing down, when it reached the low threshold it would go back to the base timing of 29.
https://datazap.me/u/turbotoy2791/lo...om=14897-15616
Old 05-28-2020, 02:27 AM   #7
tomm.brz
yeah well that is just how launch control by ecutek works, it also fuel cuts intermittently so if you want something more extreme you have to custom set it anyway
I ll take a look at your things
for next time please upload to datazap as I m on handy all day and it s stressing to upload with it
Old 05-28-2020, 07:32 AM   #8
solidsnake11
Drives: brz
Without the custom map pulling timing on launch 0psi boost at 4000rpms
With custom map 9lbs of boost at 4000rpms
let me know if the links are not open to the public. Its first time I have used google drive.
Old 05-28-2020, 07:39 AM   #9
tomm.brz
ok,
tune is ok but there is a bug , probably because you patched it with Racerom 12
i had problems with rr12 too, not exactly this, anyway
LFA state changed to a different value, and accelerator is over 85% (that s trigger for launch and flat as standard value) exactly when some sort of fuel hard cut entered, LFA means LaunchFlatfootAutoblip, it s a debug code for ecutek support
It just seems a weird random bug
Delete racerom12, put rr11.1 ,.... if it cuts again, try disabling launch control
if it cuts again, switch to A01G or A02G with rr11.1
Old 05-28-2020, 03:30 PM   #10
solidsnake11
Drives: brz
ok,
Thank you so much for your time. I just loaded A01G with rr12, I will go back to rr11.1.
Old 05-28-2020, 04:53 PM   #11
tomm.brz
can you log again with a01g?
also, can you log your launch control just a couple seconds, no need to actually launch
Old 05-28-2020, 08:10 PM   #12
solidsnake11
Drives: brz
It did it again with A01G and rr11.1. lfa3 when it cut then it went to lfa5
A01G RR11.1
Old 05-28-2020, 08:13 PM   #13
tomm.brz
weird
did you try disabling any extra features?
also send the log to ecutek support attached with your tune
They will help you figuring out more
Old 05-28-2020, 08:42 PM   #14
solidsnake11
Drives: brz
weird
Not yet it just happened minutes ago.
ABS C1288 - ECU Matching failed MatGO Issues | Warranty | Recalls / TSB 21 05-30-2022 09:19 AM
Rocker arm failed displacedTexan Issues | Warranty | Recalls / TSB 77 08-22-2018 06:16 PM
AC failed under 6 years. wparsons Issues | Warranty | Recalls / TSB 5 05-16-2018 11:08 PM
Hlep. I failed. Shaisters Northwest 14 06-02-2016 10:56 PM
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 06:27 PM
