Old 05-31-2020, 12:34 AM   #15
racingfool
racingfool's Avatar
Drives: Miata
Originally Posted by ML View Post
Lookup kirkey racing seats. The can make custom stuff too
Originally Posted by racingfool View Post
racingfool is offline   Reply With Quote
The Following User Says Thank You to racingfool For This Useful Post:
ML (05-31-2020)
Old 05-31-2020, 10:05 AM   #16
ML
ML's Avatar
Drives: 13 White MT FR-S
Whoops
Old 06-01-2020, 12:26 AM   #17
PekoPeko
Originally Posted by JONCOFF View Post
So, what's the widest seat somebody has been able to get in the car and retain sliders?
Has anyone installed an OMP HTE-R XL seat in the car? If so, how was it mounted? Brand names would help me please, following posting rules, no solicitation, no pricing.
With this forum base, some of you must have run into this.
Thanks in advance.
I have an OMP WRC XL and had a couple configurations. I'm pretty sure you won't have any of my seat issues since the HTE-R XL has almost 2 inches more clearance on both sides I believe on the shoulders and 3/4 inch on the base.
Started with a Sparco base and Sparco rails with OMP HC733 brackets. Mounting everything as far right as I could, the trans tunnel rubbed a little on the front corner and the shoulder padding rubbed a little on the door. Nothing major but was constant contact which caused the door to squeak. I also had to cut about half an inch from the slider rails as the Sparco base is at an angle and you will not be able to go full extension before the inner rails hit the floor. This combo does sit higher than stock though, maybe 1-1.5 inches or so but was comfortable and easy to put in.
I also tried the Buddy Club Super Low rails. A lot more contact on the door than the previous setup but it sits lower than stock. I was able to close the door fully so I would think that you might barely touch if at all on the shoulder. The rails are absolute garbage though so dont expect a smooth slide.
Right now I'm using the Sparco base with no rails and modified mounting points for the brackets to give me a sliver of space between the door while being lower than the Buddy Clubs. I'm the only driver so no need to move the seat but I am thinking of modifying the Buddy Club with some custom brackets for funsies.
Hope this helps.
PekoPeko is offline   Reply With Quote
Old 06-05-2020, 10:29 PM   #18
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Hope this helps.
This is essentially my setup as well. Custom drilled Planted base with Planted brackets so that the seat touches nowhere (although I did remove my headliner and b-pillar trim). Same situation as I am the only driver. Seat is plenty low enough with plenty of headroom - even with my giant head and 2xl helmet.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
How does (very sensitive) passenger seat seat belt sensor work? GrantedTaken Cosmetic Modification (Interior/Exterior/Lighting) 23 10-03-2018 12:43 PM
FS: Bride x Cusco Stradia II Reclineable Seat (SINGLE SEAT) MrMarinakos Interior Parts (Incl. Lighting) 2 07-20-2015 01:38 PM
Seat Rails: My seat will no longer slide forward or backwards? Vic_RSA AFRICA 3 05-25-2015 11:36 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
