Old 05-16-2020, 07:21 PM   #1
JONCOFF
Drives: 13 FRS, 08 Yaris, 97 318iS
Big seat for a fat boy?
I'm old and overweight, but I still enjoy track driving...I'm 5', 10" tall and weigh 255 lbs, w/a 42" waist. I need a race seat, 'cause it really doesn't work so well to be holding myself in place with the steering wheel while cornering, lol! I've got a 3" lap belt to cinch myself in, along with the factory belts, but the factory seat, as good as it is, doesn't have high enough sides for my thighs and upper body.
So, what's the widest seat somebody has been able to get in the car and retain sliders? I'd love to be able to use the Brey-Krause seat mounts which bolt to the factory slider, but even the larger set doesn't seem to accept anything more than a medium width seat. I do have an Autopower rollbar welded in the car, so I've got good harness mounting available.
Has anyone installed an OMP HTE-R XL seat in the car? If so, how was it mounted? Brand names would help me please, following posting rules, no solicitation, no pricing.
With this forum base, some of you must have run into this.
Thanks in advance.
JONCOFF is offline   Reply With Quote
Old 05-16-2020, 07:54 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Possible try to lose some weight bro. Not trying to be mean but health is wealth man. Car will go faster too.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 05-16-2020, 09:20 PM   #3
Lantanafrs2
Drives: 2013 frs red
Lol, it's not always that easy to lose weight, especially when you're older. I'm sure hes not the first "curvy" guy to do a track day. Someone will have some info.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Griever423 (06-02-2020)
Old 05-16-2020, 11:57 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
so this isn't the same issue, but another potential option.
https://www.ft86club.com/forums/showthread.php?t=123479
Old 05-17-2020, 12:14 AM   #5
HaXx
Drives: jrsc_brz
the Braum Falcon X is FIA rated and lists its fitment up to 40" waist. you can also search Bride XL and they offer a few of their models in their XL configuration, but i think making a post in you regions Facebook frs/brz group and seeing if someone has one that you can actually sit in might be best. the facebook groups tend to see more traffic and you might be able to reach more people there. 86ONE for example is the owners new england group.
https://www.braumracing.com/product/...eat-black-red/
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 05-17-2020, 12:16 AM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This helped a ton for me. Also Camry XSE headrests aren’t pushed forward as much but look the same.
Old 05-17-2020, 12:22 AM   #7
soundman98
soundman98's Avatar
that reminds me-- it was in the very early product info in 2013 or '14, but the head rests can be flipped around to make space for helmets for track days. if the stock headrests are part of the problem, it's another alternative.
i've tried it a few times just to see, and it does make for a lot more space.
Old 05-17-2020, 01:20 AM   #8
racingfool
racingfool's Avatar
Drives: Miata
I fit into this when I was heavier than you at 5'-10" also.
https://www.kirkeyracing.com/product...RO-STREET-DRAG
racingfool is offline   Reply With Quote
Old 05-17-2020, 02:30 PM   #9
It sounds like you would be comfortable in the seat from my old 1979 Lincoln Continental Mark V. Pick one up from a wrecking yard, I'm sure it would slip right in there -
Seriously, maybe have a seat custom built?
Old 05-17-2020, 02:39 PM   #10
soundman98
soundman98's Avatar
yeah, but his main issue is high side-forces while racing around a track. that's clearly a "come on over baby" seat!
*my high school years were at the tail end of that seat trend. i knew a few guy's at the time that would pick their cars based on seating 'performance'. but then the 90's on up moved towards bucket seats, and it had begun to be difficult for those 'seating enthusiasts' to find vehicles that still offered the right amount of smooth-sliding capability that more pre-90 vehicles offered.
humfrz (05-17-2020)
Old 05-17-2020, 02:49 PM   #11
Well, it would need to be modified with some "sideboards" -
soundman98 (05-17-2020)
Old 05-28-2020, 04:52 PM   #12
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Running sliders with a large seat in a BRZ creates issues beyond base width, particularly a containment seat like the HTE-R XL. Even with a fixed plate, my Sparco Ergo-L, with a similar design, required removal of the headliner to ensure proper clearance. That, however, was also a function of the fact that I am 6'3" and needed the seat pretty far back.
I know people have put OMP WRC-XLs with sliders in BRZs. Not aware of very many other large seats.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 05-29-2020, 11:14 AM   #13
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
You will need to use the PCI fixed adjustable seat mount. The OMP HTE XL will fit.
skylinekin is offline   Reply With Quote
Old 05-30-2020, 08:36 PM   #14
ML
ML's Avatar
Drives: 13 White MT FR-S
Lookup kirkey racing seats. The can make custom stuff too
How does (very sensitive) passenger seat seat belt sensor work? GrantedTaken Cosmetic Modification (Interior/Exterior/Lighting) 23 10-03-2018 12:43 PM
FS: Bride x Cusco Stradia II Reclineable Seat (SINGLE SEAT) MrMarinakos Interior Parts (Incl. Lighting) 2 07-20-2015 01:38 PM
Seat Rails: My seat will no longer slide forward or backwards? Vic_RSA AFRICA 3 05-25-2015 11:36 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
