| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
Drives: TRD R.S. 1.0 FRS
Tried that, but it felt we were about the break the bolts. Did not want to sit flush no matter what we tried. But maybe we’ll try again tomorrow morning if it comes it. Cheers |
#16 |
Drives: 2014 BRZ Limited, Satin White Pearl
Double check your new clutch disk is correct for the spline on the transmission. You will have to remove the clutch to do that. See if it slips on.
Did you replace the pilot bearing? Did you double check fitment prior to trying to assemble everything? If all are correct, make sure when reassembling that you use the tool to center the disk. Double check your alignment pins are in place, should be 2 of them. Jack the front of the engine up a bit to give more room. Push transmission onto the 2 bottom studs on engine. Get some assistance! Have someone check that while you are pushing and wiggling the trans you are keeping it parallel with the engine mating surface. You need to push and wiggle violently. Should eventually begin to slide on. Ive had it take me 2 minutes one time and up to 30 minutes another.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
| The Following 2 Users Say Thank You to Tonrogs For This Useful Post: | airrick (04-28-2020), gravitylover (04-27-2020) |
#17 | |
This^ right here. I did eventually do it but having that person on top checking when we were level and when to wiggle and shove. |
#18 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Well I just got everything apart and the transmission out. Removed without taking the shifter out just got from underneath. Didn't slide the shifter-to-transmission assembly out of the way which blocked me from removing the trans at first.
Tomorrow I will attempt to reinstall the trans some good advice on here as this is going to be a PIA. People keep saying to jack the engine up by the oil pan which only tilted the motor more forward. I jacked it from a spot right in the front of the oil pan with a piece of wood. To push the front of the motor up and the back of the motor slightly down if that makes sense.
#19 |
not playing cards
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#20 | |
as long as you get your motor and trans level thats really the important part because it should just slide in without any real real stoppage, if there is. something is up. good luck mate! |
| The Following User Says Thank You to airrick For This Useful Post: | SuperTom (04-29-2020) |
#21 | |
I would basically get it to about an inch of sliding all the way on. I made sure I really took my time aligning the clutch with the tool. Holding the tool in place while tightening down each pressure plate bolt a little at a time for the record so it seemed very aligned. I think I totally fucked up now im pissed. I jacked up front of motor till the point the intake hose popped off. I keep raming in front to back and wiggling side to side and it still wouldn't go within an inch. I cheated and started to thread the bolts a slowy pull in(I know this is supposed to be bad) go to within a half an inch and still tried to wiggle then I think I heard a ping inside the transmission. Although I didn't feel any resistance to using the bolts to pull together. Anyway I Stopped with 1/2" of space still for fear of fucking up something more. Its going to be raining all day tomorrow so Im just going to walk away for a few days. im going to keep reading and watching videos. I will probably pull everything back out unless anyone has had success using the bolts to pull it together. FUCK!!!! |
#22 | |
slowly threading the bolts is bad. if you cant move your transmission by wiggling it. there is something in the way or your splines arent aligned or your alignment came out of place because apparently it can. with that plastic alignment tool. i recommend you checking with the alignment tool on the pressure plate by move your finger around the alignment tool and make sure the gap is the same. its what i did to check alignment but thats what i did after i took everything out. I had someone hold the clutch while, i held on the aligntment tool in place and hand threaded the bolts. did you remove your transmission mount bracket? if gave me more room near the linkage area for aligning the trans and motor. Last edited by airrick; 04-29-2020 at 04:46 PM. Reason: info |
#23 | |
#24 |
If the worst thing is my clutch being messed up I wont be so mad as I was reusing my stock one with low miles. I was installing a LW flywheel and put in new TOB, velox clutch lever. I was thinking I just wasn't strong enough to get it to slide in, but some people say it should be sooo damn easy. plus I didn't feel any resistance when slowing hand tighting down the trans a little bit side to side. Anyway I will pull the trans back off and double check to see if the clutch got fucked. Thanks!
#25 |
Drives: Subaru BRZ
I'm puzzled, is there a legal requirement in your country that a car owner must do all mechanical work on his/her vehicle? The Heath Robinson contraptions to get round issues only to find that you've wrecked something else just doesn't compute with me..
#26 | |
Nope, just part where I have to give a shop legal tender. The part where you don't understand is all about learning. I mean I could pay a shop but i like the learning, and yea i messed up but i still have the knowledge now and better confidence in next time. Or you could pay for my next transmission job =D |
| The Following User Says Thank You to airrick For This Useful Post: | JD001 (04-30-2020) |
#27 | |
I also recommend to zip tie the fork to a bolt outside the trans when putting the trans back in. This way it cannot get knocked off the pivot or push the tob post the sleeve it rides on incase you accidentally hit it on the tunnel. Keep wiggling round and round until it goes on. I typically never spin the driveshaft as long as you wiggle it right, it will turn itself and go on.
| The Following User Says Thank You to Tonrogs For This Useful Post: | SuperTom (04-29-2020) |
#28 | |
Its going to be hard for me to let this go the next couple days, damn rain. And no im not taking this to someone stubbornness is part of the learning process for me |
| FS: 2016 FRS Engine/Transmission 40 k miles Invidia cat back | sokol | Engine, Exhaust, Bolt-Ons | 1 | 08-28-2019 10:55 PM |
| HKS full manifold-back exhaust for Automatic transmission? | UNREAL | Engine, Exhaust, Transmission | 14 | 08-15-2019 11:37 PM |
| Thinking of putting back stock exhaust | frsqc | Engine, Exhaust, Transmission | 31 | 07-31-2018 08:55 PM |
| Putting stock FP back on. Heat shield? | Tysoncrosby21 | Engine, Exhaust, Transmission | 4 | 01-02-2017 04:02 PM |
| Can't get rid of TPMS light after putting OEM wheels back on | customfab87 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 10-23-2016 04:54 PM |
