Old 04-20-2020, 12:25 PM   #15
churchx
churchx's Avatar
Drives: 2014 GT86
I highly suspect that all 56.1mm are same as 56 (omitting slight extra clearance for easy putting on), just depending on whim of seller how he posts that diameter.
Old 04-20-2020, 12:30 PM   #16
vladniko86
vladniko86's Avatar
Drives: FRS
Originally Posted by 86MLR View Post
Until you need to remove it, or put on a spare, especially if it is on the hub, and your trying to fit a spare.
Hammering it to make it fit is lazy and shows poor mechanical aptitude.
Just take a flat head and pry it up lmao
vladniko86 is offline   Reply With Quote
Old 04-20-2020, 12:43 PM   #17
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Have to agree with everyone just get ones that fit. But if you want to hammer it on it would likely work for normal driving. Some people don’t even uses hub centric rings and it works. That said for 20 bucks get the right thing.
Ernest72 is offline   Reply With Quote
Old 04-20-2020, 01:56 PM   #18
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You won't pry a 4/1000ths press fit off with a flathead lololol
Old 04-20-2020, 05:29 PM   #19
Infinity
Drives: 2016 Scion FR-S
This is what I am thinking. They are plastic anyways, so they might have a tiny bit of give. When I get them I will test fit them and see how it goes.
If they are not visible anyways I will probably just get some metal ones.
Infinity is offline   Reply With Quote
Old 04-21-2020, 09:22 AM   #20
Vital
Drives: 2015 BRZ
They wont be visible. Can you explain why you think they'd be visible?
Vital is offline   Reply With Quote
Old 04-21-2020, 10:41 AM   #21
Infinity
Because I will not be running center caps. I believe the hub centric rings fit around the edge of the hole where the center caps would be.
In these pics, it appears you can see the hub centric rings to me. Maybe I am mistaken?
Old 04-21-2020, 11:26 AM   #22
Yoshoobaroo
TRACKBREAD
You can always paint them
Old 04-21-2020, 11:29 AM   #23
JD001
JD001's Avatar
Drives: Subaru BRZ
What's the accepted tolerance for such things?
Old 04-21-2020, 11:47 AM   #24
Yoshoobaroo
TRACKBREAD
I painted my spacers black on my BMW, and nobody ever notices.
Old 04-21-2020, 12:24 PM   #25
Vital
Drives: 2015 BRZ
Yes you are right on the placement of the hub rings they will go behind the wheel hub.
Looking at those pics i cant even tell for sure if those have hub rings or not. Theres no way to tell for sure besides looking behind the wheel itself.
Old 04-21-2020, 01:36 PM   #26
Joon525
Joon525's Avatar
Drives: 2016 BRZ
On most wheels you can indeed tell as long as there are no center caps on them. In the picture below the owner was using orange rings.
I've owned the following wheels and on every single one I was able to see the rings without the center cap installed.
SSR Integral
Volk GT-N
Racing Hart Type-C5
Volk LE28N
Enkei RPF1
Enkei NT03
I have yet to run into a wheel where you can't see them. Does such a thing exist? Maybe! But I've not seen it yet.
In the picture that @Infinity posted the black ring is obviously there to me.
Joon525 is offline   Reply With Quote
Old 04-22-2020, 11:35 AM   #27
Icecreamtruk
Drives: Track preped NA FRS
Not necessarily true ...
If it wasn’t necessary for the wheels to be hubcentric, trust me, OEMs would not bother with it.
I dont have a single source (and im not using time to check it out) to point out why OEMs use or not hubcentric but I doubt it has anything to do with it being necessary and more to do with most OEMs not using conical lugnuts (those and acorn style, which our OEMs wheel use). It may also be for marketing reasons? How are they going to sell you those sweet 3k optional wheels? By pushing bullshit like "being hubcentric" and all the rubish a car dealer salesman will push your way.
Im not trying to be an asshole but in current cars while using lugcentric wheels and lugnuts, using hubrings is not necessary at all. Thats not to say there is something wrong with it, by all means if you have the proper ones and want to, go ahead. But what OP wants to do (grind away .1mm of diameter by hand) is 100x worse than not using hubrings at all, always take posts in context.
Lastly, 4 holes? I havent seen my car since winter started but im pretty sure there are 5.
Old 04-22-2020, 09:50 PM   #28
soundman98
ProCrastinationConsultant
soundman98's Avatar
most oem's make their wheels hubcentric by design
looking for a place that sells 56.1mm - 65mm hub centric rings Brinks Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-30-2016 12:43 PM
WTB: 65mm to 56.1mm Hub Centric Rings alexvc Want-To-Buy Requests 1 01-24-2015 05:57 PM
WTB Hub centric rings 65mm-56.1 Brinks Want-To-Buy Requests 2 08-27-2014 10:11 PM
SSR Type C RS hub centric rings Justkiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-14-2013 08:34 PM
FS: Hub centric rings 63 > 56.1 mm JDMSushi Australia Classifieds 3 02-09-2013 08:52 PM
