Old 03-29-2020, 03:07 PM   #15
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Oh and I also used silicone glue to glue down thick washers to the skid plate as spacers. I believe there were 8 total main mounting bolts. This pushed the plate down a few more mm's
SuperTom is offline   Reply With Quote
Old 03-29-2020, 09:59 PM   #16
Tokay444
There’s only room for one header. That’s likely your issue.
The Following User Says Thank You to Tokay444 For This Useful Post:
Kestrel (04-04-2020)
Old 03-29-2020, 10:50 PM   #17
Joveen
Joveen's Avatar
Drives: Bone stock
Originally Posted by SuperTom View Post
I have just installed Perrin mounts with Ace headers. Havent driven yet as I still have car on jackstands for other projects. But I will say I didn't have to remove the headers to install on my car, just jacked up the motor from the oil pan. I did remove the bolt holding the front pipe to the trans mount. Stock ones right side came out the front, left side came out the rear. Im going to say fairly easy and can be done in your driveway
Plus 2lbs lighter off the front of the car!
Can't wait for a review on these.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 03-30-2020, 09:49 AM   #18
Chamaco
Drives: Silver FR-S
Originally Posted by JIM THEO View Post
MY18 BRZ with less than 25000kms, fitted recently ACE A350 headers and Berk catted frontpipe.
I adjusted the aluminum under-tray with a hammer but after few kms of driving I realized headers rub against the subframe when I turn on the engine (engine moves slightly to the right side), when I accelerate from stop, and at high speed left corners.
I think also overpipe rubs the front sway bar, but may be is my idea as the space between those two was no more than 1cm, can't check it now due to covid19 lockdown.
My question is are the STI engine mounts and Whiteline gearbox insert enough to solve the subframe (and overpipe) rubbing problem or should I buy harder mounts or what else?
I had similar issues with mine touching the under tray and sub frame under certain conditions very similar to yours. After hammering a little bit the under tray it stopped touching there, but still on the sub frame. Later on I found out (going back to stock front and mid pipe) that my custom exhaust was too heavy and contributing in the engine shifting more when cornering (specially) to the left. After swapping my custom front pipe and mid pipe for the OEM ones I stopped having rubbing issues with my Ace350.
Maybe you catted Berk front pipe is a bit heavy? or you mounts are about to go?
Chamaco is offline   Reply With Quote
The Following User Says Thank You to Chamaco For This Useful Post:
CSG Mike (04-08-2020)
Old 03-30-2020, 11:16 AM   #19
JIM THEO
Drives: BRZ 2018
Hmmmm...this was in my mind, to gut and fit the OEM frontpipe in place of the Berk HFC frontpipe, exhaust flow and AFR will not change at all!
JIM THEO is offline   Reply With Quote
Old 03-30-2020, 11:47 AM   #20
Tokay444
It's 100% because you have mounted more than one header.
Old 03-30-2020, 12:42 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post:
SuperTom (03-30-2020)
Old 03-30-2020, 12:50 PM   #22
Tokay444
OP and title make reference to more than one header, but you think I'M high?
Old 03-30-2020, 01:24 PM   #23
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
If I wear pants, does that mean more than one pair?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
NoHaveMSG (03-30-2020)
Old 03-30-2020, 01:35 PM   #24
Tokay444
It means precicely one pair, and I'll just ask if you know what the word "pair" means?
Old 03-30-2020, 01:37 PM   #25
Tokay444
You are wearing more than one pant.
You are wearing two pants. One pair of pants.
Old 03-30-2020, 01:43 PM   #26
Tokay444
This is a header.
https://images.app.goo.gl/YnCdsxGHwF8XE7Ev5
This is a pair of headers.
https://images.app.goo.gl/87YmjXz6KoKR1yKa6
Class dismissed.
Old 03-30-2020, 01:45 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pot-Pots
The joke was along with your point of header and headers
Old 03-30-2020, 01:47 PM   #28
Tokay444
Pot-Pots
In Soviet Russia, pots joke smoke you.
Automatic Transmission issue- dealer is not recognizing the issue, please help! Arrex Issues | Warranty | Recalls / TSB 36 06-03-2019 05:15 AM
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? darkbluemn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-05-2018 09:49 PM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 10:51 PM
Headers: Has the CEL "issue" been solved? boredom.is.me Engine, Exhaust, Transmission 9 10-20-2013 10:35 PM
Do all headers for the BRZ cause the CEL issue? Oburn Engine, Exhaust, Transmission 19 05-16-2013 03:18 PM
