Old 03-16-2020, 12:02 PM   #15
Tokay444
Definitely not the OEM plug.
Old 03-17-2020, 12:16 PM   #16
qqzj
Drives: MDX, Camry
Originally Posted by Halo_2 View Post
Think you answered your own problem, stripped thread.
If your going to use a torque wrench on small bolts use a 1/4 or hand torque but hand near the head of the ratchet.
Learnt the hard way too using torque wrenches sometimes its not worth using them.
The problem is that he used 1/2 inch torque wrench, which is very imprecise at around 30 ft lbs. 1/4 inch tw is also useless here. What is needed is 3/8 inch torque wrench. OP has insufficient experience with tools. Not the tools fault. I actually don't bother with tw for this. Just use a regular 3/8 wrench, which is pretty short, and give it a hard turn. That's all.
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
Old 03-17-2020, 02:10 PM   #17
Halo_2
Drives: 2014 MY15 86 GTS
The other reason not to use a torque wrench is its got oil on the thread so your going to over torque the bolt.
Plus its not a critical bolt ie. head bolt.
Halo_2 is offline   Reply With Quote
The Following User Says Thank You to Halo_2 For This Useful Post:
soundman98 (03-17-2020)
Old 06-16-2020, 12:54 AM   #18
Brooklyn
Brooklyn's Avatar
Drives: 2014 DGM BRZ
Just to circle back and close the thread on this:
I removed the (non-OEM) drain plug and drained my oil. Upon inspection, it looks like the excessive force I put on the bolt by using my 1/2" drive made the drain plug cave in on itself.
I installed the fumoto valve according to the instructions and the leak seems to have stopped...hopefully forever. I was/am however worried I cross-threaded the threads but I'll keep an eye on it. Thanks all for the input. Hopefully others can learn from my mistake!
Brooklyn is offline   Reply With Quote
The Following 3 Users Say Thank You to Brooklyn For This Useful Post:
bcj (06-16-2020), Spuds (06-18-2020), Subsonic (06-16-2020)
Old 06-16-2020, 01:32 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Brooklyn View Post
\ I put on the bolt by using my 1/2" drive made the drain plug cave in on itself.
1/2 Drive
The Following User Says Thank You to NoHaveMSG For This Useful Post:
humfrz (06-16-2020)
Old 06-16-2020, 05:02 PM   #20
Brooklyn
Brooklyn's Avatar
1/2 Drive
The Following User Says Thank You to Brooklyn For This Useful Post:
NoHaveMSG (06-16-2020)
Old 06-16-2020, 05:17 PM   #21
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
If it went in smoothly and easily until the gasket touched, you're fine!
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Brooklyn (06-17-2020)
Old 06-17-2020, 02:33 AM   #22
humfrz
1/2 Drive
Yep, OP, get yourself a 3/8" drive socket set with one of those short 5-6" ratchets. You will bust up a lot less stuff.
Put the 1/2" drive socket set down in the compartment of your tool box with the blow torch, BFH and crowbar.
Brooklyn (06-17-2020), NoHaveMSG (06-17-2020)
Old 06-18-2020, 11:07 AM   #23
radroach
Drives: car
fumoto valve ftw
The Following 2 Users Say Thank You to radroach For This Useful Post:
humfrz (06-18-2020), soundman98 (06-18-2020)
Old 06-18-2020, 08:26 PM   #24
humfrz
Originally Posted by radroach View Post
fumoto valve ftw
fumoto valves are for woosies. -
Real men use this. -
Finally fixed the oil leak - Warning for those still using OEM drain plug/gasket. lupindub Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 02-25-2016 08:47 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Best magnetic drain plug? FR-Sizzle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-28-2015 02:07 PM
Oil Drain Plug Size jjkerr626 Engine, Exhaust, Transmission 3 11-28-2014 07:20 PM
Help! - slow leak from oil drain plug amram Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 05-28-2014 03:42 PM
