Old 09-05-2012, 02:27 AM   #15
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
lol are you guys' serious? That's an functioning LSD. It's NOT a problem, that is how the clutch in the rear differential coming to an immediate stop sounds like.
Now iff you want to get rid of it, I'll be more then happy in trade you for a non LSD differential + a little cash on top of it. You'll be in the world of 1 tire fires, but I'm sure the majority of guys' on this board won't mind it too much as there cars will probably never see a real track.
But seriously if you want a non lsd diff, like I said I'll trade you one that fits in your fr-s/brz for your factory one. LMAO
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 09-05-2012, 02:36 AM   #16
Tunz
Drives: WRB BRZ Limited
So my lsd only started to function after 1300 miles? This noise didn't happen until recently.
Tunz is offline   Reply With Quote
Old 09-05-2012, 02:39 AM   #17
wheelhaus
wheelhaus's Avatar
It's a Torsen LSD, gears only, there are no clutch plates in the factory LSD.
wheelhaus is offline   Reply With Quote
Old 09-05-2012, 02:41 AM   #18
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
You probably just never really noticed it...
Omar GC
Instagram: 2jzus
Old 09-05-2012, 02:41 AM   #19
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Kudos, thank you for the heads up
Omar GC
Instagram: 2jzus
Old 09-05-2012, 02:43 AM   #20
TheProspect
TheProspect's Avatar
Drives: Hot-Lava fr-S Smoked Tail Lights
Has anyone tried to downshift aggresively from 5th to 4th? I have done it and most of the time it feels as if it cattches on something and doesn't engage unless i clutch a few times and let the rpms go down a little... HELP!!!
My VTec Goes BWwWwWaAAaAaAAAAAaAaHHHHH!!!!!!
TheProspect is offline   Reply With Quote
Old 09-05-2012, 02:46 AM   #21
Tunz
Maybe, I'll find out on Friday. Thanks everyone for your input.
Old 09-05-2012, 01:56 PM   #22
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I notice the rear clunk shifting into first while at a stop (unless I hold the clutch in for 3 seconds), shifting into 2nd, 3rd, and 4th. It's not constant, but it does happen every day.
I've also noticed what I believe to be the same rear clunk while cruising at expressway speeds. If I let off the gas and wait a second for the car to engine brake (leaving the car in gear obviously) and then do any throttle tip in other than very lightly it happens.
I'm not really concerned about it yet, but being that my past job had me evaluting cars for a major car OEM for 6+ years I can't help but focus on it.
Chimpo is offline   Reply With Quote
Old 09-05-2012, 02:43 PM   #23
jesperswe
Drives: GT86
Most RWD cars (including my 3 day old Toyota GT86) make some strange clunk and boinks, there are more thing that moves and stops compared to a regular FWD car. Usually i think it's just driveshaft play since it's not just 1 solid bit.
My old Supra used to clunk alot when shifting etc
Also my last Evo 9 clunked now and then when you are not super gentle with the clutch. My last dailydriver VW Passat FWD was dead quiet though
jesperswe is offline   Reply With Quote
Old 09-05-2012, 03:14 PM   #24
wheelhaus
wheelhaus's Avatar
It's possibly the diff housing bushings, I know Imprezas were notorious for a clunk under hard shifting.
Old 09-21-2012, 03:21 PM   #25
bestwheelbase
Drives: 1985 P-Type
I am very sensitive to these things. My Cadillac was so clunky it ruined the driving experience.
Old 07-23-2024, 10:26 PM   #26
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Super thread rescuscitation.
I'm getting this after 128k miles. I do have one of the rear diff bushings worn out. The worse it wears, the worse the clunk gets. I have on hard pull, then shift, worst on 1-2 shift. I can go soft and eliminate driving. I crawled under my car tonight to look for some interference to account for the noise. I found an exhaust clamp bumping the steel tank cover a bit, but that wasn't it.
I can't find any metal to metal rubbing/clunking anywhere. I'm thinking the shot bushings have some metal capture in them that's smacking together now that the bushing material is shot. I had this happen on one of my jeep engine mounts. I can't explain the noise any other way at the moment. And I'm not sure how these bushings are put together, my answer is pure theory.
In my case, it sounds like it's coming from the back left, but may just be the center where the bushing is. Sounds further back than the transmission bushing, and I just put the whiteline bit in there far enough back it shouldn't be it as I torqued it down good, and I'd hear and feel that under the center console.
jeepmor is offline   Reply With Quote
Old 10-01-2024, 12:10 AM   #27
jacobe38
@slothbrz on IG
jacobe38's Avatar
Drives: Track BRZ - Supercharged
did you ever track this down?
my 80k mile frs is making a noise from the rear on every up shift.
jacobe38 is offline   Reply With Quote
Coilover Clunk (Brand new) white86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 02-10-2016 11:24 PM
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 06:49 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 06:09 PM
Parking brake clunk FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 06-28-2012 01:10 AM
Thud/Clunk when shifting. erom Engine, Exhaust, Transmission 10 06-17-2012 08:08 PM
