Old 01-27-2020, 10:21 PM   #15
norcalpb
norcalpb's Avatar
Do you have the suspension on right now? If there’s no binding, or noise, you are good to go.
Old 01-28-2020, 03:58 AM   #16
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
Its not on right now. Just want to make sure I'll have everything I need.
Ryan GT86 is offline   Reply With Quote
Old 01-28-2020, 04:14 AM   #17
86MLR
86MLR's Avatar
Measure and see if mounting points are different.
My MCA coilover came with longer links because they recommend a 20mm drop.
The MCA links were around 20mm longer IIRC.
The mounting points were same as OEM struts.
Not having your sway bar geometry right will effect their performance.
Have a google.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 01-30-2020, 02:25 PM   #18
Stomachbuzz
Drives: 2013 FRS
Originally Posted by gpvecchi View Post
I still not understand what's the need for endlinks. Every (almost) aftermarket strut has the attachment of the endlink in the same place of the OEM, so the sway bar will not be lovered to the ground. So no need for shorter endlinks...
When the suspension (strut) lowers the car, what it does is it lowers the top hat.
As the body of the car is lowered, the sway bar is lowered with it. This makes the sway bar further from the connection point on the strut. Creating the need for a longer endlink.
It's possible that some aftermarket struts/coilovers modify the position of the sway bar connection point, I don't know, but that would change the geometry and the behavior of the sway bar.
This is a classic example of sprung vs. unsprung weight/components.
Picture taken from: http://brz-frs.blogspot.com/
Stomachbuzz is offline   Reply With Quote
Old 01-30-2020, 02:53 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
On our cars this is a fixed length regardless of ride height. What dictates needing a shorter link is clearance to other suspension components. I am over 1.5" lower, stock length links.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
gpvecchi (01-30-2020)
Old 01-30-2020, 11:07 PM   #20
MaverickMonk
Drives: 13 BRZ Limited
I’ve been asking about this for a while regarding whether I need different endlinks when I lower, and I’m still unsure, but I’m gonna put on my enjinear hat for a sec and think out loud.
Because there’s a lateral arm on the sway bar, and it’s free rotating...
As long as the change in ridehight (at rest and also compression) is lower than the radius of (axis of the swaybar to the endlink bolt on the sway bar), and there’s no physical interference to the other suspension components in that range of motion, the system should perform the same as it did stock.
Right?
MaverickMonk is offline   Reply With Quote
The Following User Says Thank You to MaverickMonk For This Useful Post:
NoHaveMSG (01-31-2020)
Old 01-30-2020, 11:13 PM   #21
Stomachbuzz
Drives: 2013 FRS
It needs to be longer, not shorter.
Old 01-30-2020, 11:46 PM   #22
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My coils came with shorter end links.
I LIKE TIRES!
APR GT250 67 Inch wing w/ 7 Inch risers on SEIBON CSL Style CF Trunk Tony.86_ Exterior Parts (Aero, Lighting, Etc.) 5 01-03-2020 11:03 PM
WTB: around an inch lowering springs (1.25 in dropish) ReaperBRZ Want-To-Buy Requests 1 03-02-2017 12:08 PM
Blowout Sale Ambit Wheels 5x100 17 Inch & 18 Inch!! JonMotoring Wheels and Tires 14 11-16-2015 07:24 PM
1 Inch Lowering Springs and Stock Structs less than 19k miles Cross Arizona 8 05-07-2015 08:05 PM
WTB: used 1 inch lowering springs... ttrentt Brakes, Suspension, Chassis 6 03-23-2013 02:38 PM
