Old 01-27-2020, 02:26 PM   #1
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
Will I need shortened endlinks for a 1.25 inch lowering?
Will I need shorter endlinks for a 1.25 in. drop in the front if I'm on CSG Tein Flex A coils, stock front LCA, and stock sway bars? How will shorter endlinks affect handling?
Ryan GT86 is offline   Reply With Quote
Old 01-27-2020, 02:30 PM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
need? no
should, yes
Clutch Dog is offline   Reply With Quote
Old 01-27-2020, 02:57 PM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Shorter end links will make it worse.. If anything, you'd want them longer to adjust for your ride height. As you go lower, the pickup point on the strut gets further away from the stabilizer bar paddle.
BigTuna is offline   Reply With Quote
Old 01-27-2020, 03:04 PM   #4
Ryan GT86
Ryan GT86's Avatar
Wait. I thought you need shorter endlinks to clear the front LCA
Old 01-27-2020, 03:06 PM   #5
Clutch Dog
shorter is right, in either case
you want adjustable to set the sway at 0 preload with it sitting on level ground, that will give it the most swing with weight transfer and you wont have to overcome that load, it makes for a wonky driving feel.
Old 01-27-2020, 03:08 PM   #6
Ryan GT86
Ryan GT86's Avatar
What are some good adjustable endlinks then? Do I need endlinks for the rear?
Old 01-27-2020, 03:10 PM   #7
BigTuna
BigTuna's Avatar
to keep the proper stab bar geometry you'd need longer ones. As you shorten the coilover, the hub, moves up, away from the stab bar. The rear you'd need shorter links, but for the fronts, you need longer ones.
The Following User Says Thank You to BigTuna For This Useful Post:
Stomachbuzz (01-30-2020)
Old 01-27-2020, 03:14 PM   #8
Clutch Dog
I would recommend anything more race focused thank a standard company.
Ive had good luck with Racer-x and SPL which are a bit pricer than the standard stuff, but theyll last a while
and to emphasis it all depends how you lowered the car. on my coilovers the shock body didnt change relative position to the height of the car. where it mounds is the same on the spindle. but when the car sides lower the sway bar effectively raises.
Old 01-27-2020, 03:15 PM   #9
strat61caster
strat61caster's Avatar
You're assuming OP's aftermarket coilovers maintain the same swaybar mounting point as stock on the strut housing. Most don't.
ineedyourdiddly
BigTuna (01-27-2020)
Old 01-27-2020, 03:18 PM   #10
Ryan GT86
Ryan GT86's Avatar
Do the Tein Flex A's retain the stock swaybar mounting point? Ugh, yeah this is pretty annoying on figuring out what I'll need for the car.
EDIT: I heard about Whiteline adjustable end links but I'm looking to stay away from them since Whiteline has a reputation of breaking on track.
Old 01-27-2020, 03:25 PM   #11
Clutch Dog
i can vouch for not only the G86/FRS models, but also the STI and RX8
i think the metal they use for their threads are brittle and soft, cause i rounded two sets of threads, the rx8 guy snapped his and the sti guy bent his.
their sway bars also have clearancing issues with the lower control arms. too fat
Old 01-27-2020, 03:26 PM   #12
Clutch Dog
For the tein's I would just get a standard length adjustable one. esp if you are only going down 1 inch
I got a set of SPL shorts and they were too short for my drop at 2.25 in the front
Old 01-27-2020, 03:58 PM   #13
strat61caster
You're buying CSG's special parts, I'd contact CSG and include their recommended end links in the order, they've got good track experience and hopefully won't steer you wrong.
Although hopefully it's not the >$200 end links from SPL...
ineedyourdiddly
Old 01-27-2020, 05:17 PM   #14
gpvecchi
gpvecchi's Avatar
I still not understand what's the need for endlinks. Every (almost) aftermarket strut has the attachment of the endlink in the same place of the OEM, so the sway bar will not be lovered to the ground. So no need for shorter endlinks...
gpvecchi is offline   Reply With Quote
APR GT250 67 Inch wing w/ 7 Inch risers on SEIBON CSL Style CF Trunk Tony.86_ Exterior Parts (Aero, Lighting, Etc.) 5 01-03-2020 10:03 PM
WTB: around an inch lowering springs (1.25 in dropish) ReaperBRZ Want-To-Buy Requests 1 03-02-2017 11:08 AM
Blowout Sale Ambit Wheels 5x100 17 Inch & 18 Inch!! JonMotoring Wheels and Tires 14 11-16-2015 06:24 PM
1 Inch Lowering Springs and Stock Structs less than 19k miles Cross Arizona 8 05-07-2015 07:05 PM
WTB: used 1 inch lowering springs... ttrentt Brakes, Suspension, Chassis 6 03-23-2013 01:38 PM
