Old 01-18-2020, 05:13 PM   #15
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by solidONE View Post
https://www.ft86club.com/forums/show...&postcount=107
201WHP on E85 on 949's car and dyno using and ACE header and delicious tune. 200whp on 91 in ideal conditions with everything set up perfect... maybe. 180 WHP on 91 ain't bad either, considering the torque curve.
i do not care at all anymore of absolute numbers
only relative gains before-after on the same exact dyno
and yea those torque curves are great!
i do not believe the DT's relative gains also
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
CSG Mike (01-20-2020), Tristor (01-24-2020)
Old 01-18-2020, 08:34 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Who being sane cares about absolute results, when every dyno reads differently. Only relative gains against known baseline (preferably against something easily repeatable & common, eg. untuned stock) should ever be used for at least rough comparison.
The Following 3 Users Say Thank You to churchx For This Useful Post:
CSG Mike (01-20-2020), tomm.brz (01-18-2020), Tristor (01-24-2020)
Old 01-19-2020, 12:23 PM   #17
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
We'll have to look, but I'm pretty certain 949 took baselines for their Blub right after picking it up from Carmax, before they started to work on it.
http://www.ft86club.com/forums/showp...2&postcount=37
Intent > Content
The Following 3 Users Say Thank You to solidONE For This Useful Post:
JIM THEO (01-19-2020), tomm.brz (01-19-2020), Tristor (01-24-2020)
Old 01-19-2020, 12:31 PM   #18
tomm.brz
that s totally believable
and seems different to what Delicious claim, specially peak hp gains
Old 01-19-2020, 12:57 PM   #19
solidONE
solidONE's Avatar
I dont feel like Delicious Tune's dynos were 'un-believable'.
Let's just say it was under 'ideal conditions' that they yielded more compared to their baseline than some others. It is what it is. lol
Intent > Content
Old 01-19-2020, 01:39 PM   #20
PulsarBeeerz
Drives: JRSC BRZ SOLD
Maybe 4th vs 5th gear runs and an actual Dynojet vs a Dyno Dynamics setup to read like a Dynojet. Things to consider.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Lantanafrs2 (01-19-2020)
Old 01-19-2020, 02:09 PM   #21
Lantanafrs2
Drives: 2013 frs red
Honest dyno charts dont sell parts
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
DAEMANO (01-20-2020), tomm.brz (01-19-2020)
Old 01-19-2020, 04:06 PM   #22
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I've mentioned this before but mouth-pieces with parts to sell and gullible people who want to believe in the gains they think they bought tend to shut me down on this; Every believable independent dyno test on the A350 header with DT showed gains that are typical of other headers on the market and fall short of DT's marketing. Most people see no more than ~15whp peak gains on 91AKI with charts that don't look too different from the one posted by 949 above although most see a bit more peak gain than that.
There are people out there with stock -> modified peak gains on same (independent) dyno and fuel out there showing over 40whp gains although those people typically show low baseline readings and end up with typical modified readings. I've seen a few guys reporting around 140whp base reading and header+tune ending up at 190whp. A gain of ~50whp (or approx 25% gain) while NA is astronomical but the final number isn't unexpectedly high, it's that the baseline is usually unexpectedly low. In these cases, my suspicion is that they probably had an undiagnosed issue that was robbing power (partially clogged cat or issue with the stock tune) and the catless header and/or aftermarket tune resolved it.
Food for thought anyways.
Lynxis is offline   Reply With Quote
The Following 4 Users Say Thank You to Lynxis For This Useful Post:
DAEMANO (01-20-2020), tomm.brz (01-19-2020), Tristor (01-24-2020), weederr33 (01-19-2020)
Old 01-19-2020, 04:08 PM   #23
tomm.brz
50whp, if done on the same dyno same condition, is believable only with e85
come on guys, stop the joke.....
50whp are the claimed gains of a stock hks v2 supercharger with 93oct and 39mm restrictor and HKS tune
and someone wants me to believe to gain 50whp with a NA FA20 with shitty fuel
The Following User Says Thank You to tomm.brz For This Useful Post:
Lynxis (01-19-2020)
Old 01-19-2020, 04:30 PM   #24
Lynxis
Lynxis's Avatar
I don't believe it even with e85. Believable jumps in performance from bone stock on 91aki to full intake/exhaust and e85 puts most people at ~30whp peak gains assuming no other issues.
I don't mean to take away from Ace products. Compared 1:1 with every other header on the market, they ARE superior, but independent tests have resulted in no more than 5whp peak gain over alternatives. If you want the absolute best, ACE *IS* the header to get but compelling alternatives exist at half the price.
The Following 3 Users Say Thank You to Lynxis For This Useful Post:
DAEMANO (01-20-2020), JIM THEO (01-20-2020), Tristor (01-24-2020)
Old 01-19-2020, 04:32 PM   #25
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Neither of these are the ACE but I noticed very little difference between the Cosworth and HKS headers I've had. I think most will do just fine unless you're trying to be a dyno queen or want every ounce of power squeezed out of an NA engine.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
nikitopo (01-24-2020)
Old 01-19-2020, 04:46 PM   #26
tomm.brz
i have ace header 350 anyway
of course I didnt pay the crazy 1700 dollars they ask on CSG or delicious or whatever it is lol
but a looot less
they like to say they have the exclusive but it s not true
and i m the first also on saying they are superb and best header I have tried anyway
they gave me crazy gains on my hks supercharger, giving me the opportunity of running leaner and more advanced timing
But on NA it s a bit different story, and I hate the exaggeration
Old 01-19-2020, 05:07 PM   #27
86MLR
86MLR's Avatar
Full catless exhaust?
Dyno time?
Intake?
I keep seeing results from different header designs, not the supporting mods.
I think that all modifications need to be taken into consideration, especially whether the exhaust is modified after the header.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 01-19-2020, 05:56 PM   #28
tomm.brz
Dyno time?
Intake?
Not like a different airbox than stock, or a bit more free exhaust line gonna change much in a NA car
Just maybe the front pipe, that if catted could net as little as 5hp (or even less) less in higher rpm, but stock airbox is not restrictive at all
What's funny, is that DT claims those huge gains , with shitty fuel and stock airbox and stock front and stock catback... lol just make laugh more and more i think about it
Gruppe S Headers j_ros94 Engine, Exhaust, Bolt-Ons 5 05-25-2019 09:08 PM
FS (So Cal) Gruppe-S Headers Unmarried OFT Sros1031 Engine, Exhaust, Bolt-Ons 2 02-08-2018 09:16 AM
OFH 3 vs Gruppe-S Headers.. RichardJ Engine, Exhaust, Transmission 24 04-09-2017 10:20 PM
WTB: Gruppe-S UEL Headers Russo Want-To-Buy Requests 1 03-15-2017 10:45 AM
