#15 |
Drives: '14
#16 |
not playing cards
Wipe the back side of the SC pulley. I bet it has a thin grimy film. The exhaust just looks like it has some shit cooked on it.
#17 | |
Drives: '14
It would make sense if it's SC oil, but my SC oil level is fine, which leads me to think it's PCV blowby but I just don't understand how that is going in there, unless that is how it's supposed to be. |
#18 | |
not playing cards
The compressor section is supposed to be isolated from the gearbox. I don't think the gearbox is vented but I'm not sure how that works. I only have experience with Sprintex units. If you can remove the filler cap and cover it with your finger while it's running, you can check for positive pressure. There should be none. If there is, one or both of the rotor shaft seals is blown, if there is none then, meh. Unless there's a noisy bearing, change the input shaft seal when you get annoyed with cleaning stuff.
| Unusually high oil temps? | mistople | Engine, Exhaust, Transmission | 20 | 04-25-2018 02:18 AM |
| Coolant Temps Running High | Dezoris | Tracking / Autocross / HPDE / Drifting | 43 | 09-29-2016 11:58 AM |
| Coolant Temps WAY TOO HIGH | itsjustdavep | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 45 | 08-25-2016 01:41 PM |
| Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 03:17 PM |
| ECU pulls timing at high oil temps? | brillo | Engine, Exhaust, Transmission | 24 | 03-31-2013 09:10 PM |
