Old 01-02-2020, 09:05 PM   #15
Stomachbuzz
Drives: 2013 FRS
Pre-cat and post-cat measurement. But without a baseline on what a normal cat is, it isn't going to tell you much except what yours is currently reading.
If the exhaust is hotter post cat, then it's working.
Stomachbuzz is offline   Reply With Quote
Old 01-02-2020, 09:09 PM   #16
vladniko86
vladniko86's Avatar
Drives: FRS
Did you take a look at the photos?
vladniko86 is offline   Reply With Quote
Old 01-02-2020, 09:12 PM   #17
Stomachbuzz
Drives: 2013 FRS
I did. And I have no idea what's going on or what they are supposed to show
Old 01-02-2020, 09:13 PM   #18
vladniko86
vladniko86's Avatar
Drives: FRS
Yeah I should’ve written down what I measured.
Old 01-02-2020, 09:17 PM   #19
Stomachbuzz
Drives: 2013 FRS
Aye.
I also don't think you need me to interpret anything.
It's a pretty simple litmus test: if thermometer reports temps above ~350F, you're probably good.
If cannot get thermometer to report 350F, then further investigation is required.
You might not be able to get a good reading from the top of the engine bay due to line of sight being blocked by the heat shielding. Not sure. You might have to jack the car up or put it on a lift while still hot.
Also, might be a good idea to do the same test on another vehicle for a baseline, as mentioned before. Just so you get an idea of how it works
Old 01-02-2020, 09:18 PM   #20
vladniko86
vladniko86's Avatar
Drives: FRS
Aye.
That’s exactly what I’ll do! Thanks
Old 01-03-2020, 12:06 AM   #21
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I hate cats. They eat native wildlife so if you want to burn a cat go right ahead but I have no idea how common the practice is.
Old 01-03-2020, 12:16 AM   #22
86MLR
86MLR's Avatar
I think that cat is waiting for the bus to the cat farm.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 01-03-2020, 02:03 AM   #23
Lantanafrs2
Drives: 2013 frs red
A little late with that water. I think the cat would rather have been punched out than burned up. I wonder if "catless" headers offend him
Old 01-03-2020, 11:17 AM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
So I went around the block and got the car to operating temps.
https://share.icloud.com/photos/09Yy...NUq0t-11kA5x9Q
Those optical temp guns read in a cone. At that distance you are not picking up anything of use. You need to pull the lower pan off and check it from up close, maybe within 6 in max.
Old 01-03-2020, 06:15 PM   #25
ls1ac
ls1ac's Avatar
Once again late to the party, if it is a bad cat then it is covered by fed replacement requirement law.
(May not be required if extensive exhaust modifications have been done)
Old 01-03-2020, 06:16 PM   #26
vladniko86
vladniko86's Avatar
Drives: FRS
Interesting. Any warranty I have is voided so I doubt it. Also this all happened post recall
Old 01-03-2020, 06:30 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
EPA requirement is 8 years or 80K miles. All emission control devices have mandated federal warranties.
I write the emission control warranty statement for the equipment we build here at my work.
Old 01-03-2020, 06:31 PM   #28
vladniko86
vladniko86's Avatar
Drives: FRS
Even salvage branded?
TOMs Tails are Starting to Burn Out Cjymiller Cosmetic Modification (Interior/Exterior/Lighting) 18 12-28-2015 07:32 PM
How to burn your Lambo down in Dubai. mav1178 Other Vehicles & General Automotive Discussions 14 10-10-2015 10:01 PM
If you have $500 to burn, what parts would you get? retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 73 08-08-2013 02:32 PM
curb burn on gunmetal wheels three3y3wrbbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-28-2013 03:07 AM
