#15 |
Drives: 2013 FRS
#16 |
Drives: FRS
#17 |
Drives: 2013 FRS
#18 |
Drives: FRS
| The Following User Says Thank You to vladniko86 For This Useful Post: | Stomachbuzz (01-02-2020) |
#19 |
Drives: 2013 FRS
Aye.
I also don't think you need me to interpret anything. It's a pretty simple litmus test: if thermometer reports temps above ~350F, you're probably good. If cannot get thermometer to report 350F, then further investigation is required. You might not be able to get a good reading from the top of the engine bay due to line of sight being blocked by the heat shielding. Not sure. You might have to jack the car up or put it on a lift while still hot. Also, might be a good idea to do the same test on another vehicle for a baseline, as mentioned before. Just so you get an idea of how it works |
#20 | |
Drives: FRS
That’s exactly what I’ll do! Thanks Sent from my iPhone using Tapatalk |
#21 |
Because compromise ®
Drives: Red Herring
I hate cats. They eat native wildlife so if you want to burn a cat go right ahead but I have no idea how common the practice is.
#22 |
I think that cat is waiting for the bus to the cat farm.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| The Following User Says Thank You to 86MLR For This Useful Post: | soundman98 (01-03-2020) |
#23 |
Drives: 2013 frs red
A little late with that water. I think the cat would rather have been punched out than burned up. I wonder if "catless" headers offend him
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | soundman98 (01-03-2020) |
#24 | |
Drives: Crapcan
Those optical temp guns read in a cone. At that distance you are not picking up anything of use. You need to pull the lower pan off and check it from up close, maybe within 6 in max.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Stomachbuzz (01-03-2020), Ultramaroon (01-03-2020) |
#25 |
Once again late to the party, if it is a bad cat then it is covered by fed replacement requirement law.
(May not be required if extensive exhaust modifications have been done) |
| The Following User Says Thank You to ls1ac For This Useful Post: | vladniko86 (01-03-2020) |
#26 | |
Drives: FRS
Interesting. Any warranty I have is voided so I doubt it. Also this all happened post recall Sent from my iPhone using Tapatalk |
#27 | |
Drives: Crapcan
I write the emission control warranty statement for the equipment we build here at my work. |
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (01-03-2020) |
#28 |
Drives: FRS
| TOMs Tails are Starting to Burn Out | Cjymiller | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 12-28-2015 07:32 PM |
| How to burn your Lambo down in Dubai. | mav1178 | Other Vehicles & General Automotive Discussions | 14 | 10-10-2015 10:01 PM |
| If you have $500 to burn, what parts would you get? | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 73 | 08-08-2013 02:32 PM |
| curb burn on gunmetal wheels | three3y3wrbbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-28-2013 03:07 AM |
