#15 |
Drives: 2013 FRS
I got a set of OEM plugs, ill put them in tomorrow. I got an email back from Edelbrock to check out the bypass actuator.
The car idles perfectly and cruises just fine. Its only WOT boost where its stumbling. |
#16 | |
2013 Series 10 FRS #553
#17 | |
Drives: Q5 + BRZ + M796
Just to clarify, the car will run like shit, especially on boost or at serious load after reconnecting the negative battery terminal. You have to cruise around and turn the car off and on before the system goes out of this check mode. Even still, it will feel less sharp and responsive for a while until it relearns. I don’t think your problems is or ever was the spark plugs. They don’t fail so precipitously. Moreover, how did they look? Was there visible damage, especially on cylinder 1’s spark plug? I’m guess not, and I don’t think the other plugs would do so poorly, even at a significant gap change.
#18 | |
Drives: 2013 FRS
what is this check mode you speak of? With an ECUTEK I should be ready set go? thats all I did when I installed the SC. The car was having a problem before I even started working on it. So either I have a sensor gone bad or engine failure. Its idling perfectly fine. I flat out dont get it |
#19 | |
The question is what caused the misfire in the first place? Fuel, spark? Did you look at the plugs and notice aging or damage when you replaced them, especially on the cylinder that was misfiring? You had a CEL with the misfires, but now the car drives worse, yet you have no knew codes. Isn’t that odd? Also, there are people on original plugs with double your miles and stock plugs with three to four times the stock power, so my feeling is that the plugs were fine and the new ones might not be the problem. Maybe this is a fueling issue. I don’t know. What is your fueling setup? I could be wrong. Just seems odd.
#20 |
Drives: 2013 FRS
i think i found my problem. I think I have a dead coil or injector.
#21 |
Drives: 2013 FRS
now i see different part numbers for 2013 FRS, and another part number for later years. are the coils interchangeable? what should i get? if its a coil?
#22 | ||
https://www.ft86club.com/forums/show...38&postcount=5 Quote:
#23 |
You said you are running an Edelbrock SC, but are you on a CARB tune with stock injectors? What's your setup? Stock pulley (looks like it)?
#24 |
Drives: 13' Brz
Its your ignition coil, its a common issue on the 13-14 models. I had the same issue, idle, and cruised fine until i wot around 5k rpms it would misfire. Id change all the spark plugs too with it. Swap the coil to another cylinder to see if the code switches to another cylinder.
#25 | ||
Drives: 2013 FRS
#27 |
Drives: '14
| What did I do wrong? | Hags86 | Tracking / Autocross / HPDE / Drifting | 8 | 02-25-2015 01:36 PM |
| This must be wrong... | Ongor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-23-2014 11:29 AM |
| What's wrong with this car? | Suberman | CANADA | 41 | 01-14-2014 12:35 PM |
| What's wrong with my HID kit? | seven | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 11-28-2012 07:36 PM |
