Old 01-03-2020, 01:58 PM   #15
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
What about under throttle off vacuum deceleration? Also could it be perceivable then that there is a slight pulsing effect that draws a slight amount of exhaust gas back?
These are serious questions as I honestly don't know. It does however seem unlikely that the bits of the cat would make it all the way back up and into the engine.
It's hard to tell by looking at the photo, but the dislodged cat still seems to be mostly intact. So maybe those bits are from something else besides the failed cat?
I've heard many explanations as to why the pieces get sucked into the engine over the years, but can't say for certain.
What I can say is that engine failure from a precat collapse is a thing that happens, and is usually the result of unburnt fuel going into the exhaust system from a rich tune. It's a common problem with the Nissan QR25, which I had in a 2003 Sentra Spec V. In this case, if not a manufacturer defect, it could have either been from the engine relearning and dumping too much fuel into the engine, or a tune on the car which was intended to make pops and crackle noises (done by dumping fuel into the exhaust). Also plenty of other possibilities that my limited experience can't identify, since none of us seem to be mechanics around here.
https://www.b15sentra.net/forums/sho...d.php?t=135241
https://www.bobistheoilguy.com/forum...39188&page=all
https://www.maseratilife.com/threads...21/#post-23243
https://www.caradvice.com.au/687702/...p-crackle-pop/
Clipdat (01-05-2020)
Old 01-03-2020, 03:06 PM   #16
SugarBrz
Guest
Posts: n/a
Originally Posted by CrowsFeast View Post
wth, it cracked the valve cover? That's rather extreme... I don't know that the cats are the things to blame on this one.. I know you said it happened right after the install but I've had enough secondary things pop up after I do an unrelated job on my car that I believe in coincidences now.
Also, doesn't that material look more like paper on the piston? Do you have a paper air filter?
I suppose it's possible that with a sufficient blockage; when the intake valve opens at the top, just before the exhaust closes (so during scavenging) that you could actually get back flow. It just seems so unlikely. My dad's truck years ago had the cat melt into a near solid blockage and it just had no power; no other damage (granted it's a truck engine).
*Also not a professional mechanic; just some guy on the internet.
As I wrote before it, me and a close friend had the same damages to our cars. In both cases the mechanic told us that the JDL Catalyzer was the cause. There’s a reason why they limited the warranty for track use and sc engines to only 90 days.
And both cars where using the HKS drop in airfilter, I think the damage was so big because of the combination of the catalyzer malfunction, low quality and the forced induction.
You see similar damages to Diesel engines when particle filter is blocked, the higher pressure causes often an turbo damage which often damages the engine when it’s late recognized.
Also both HKS SC Kits worked fine with ft86speedfactory catted UEL header. The engine of my friend was a fully build HKS 2.1 stroker engine and both supercharger kit have been installed by a professional company, so it was not an dyi.
The Following User Says Thank You to For This Useful Post:
Old 05-15-2020, 05:56 AM   #17
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Are you putting now back the ft86speedfactory catted header ?
Old 05-19-2020, 07:34 PM   #18
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Who tuned the car?
Old 07-08-2020, 07:38 AM   #19
SugarBrz
Guest
Posts: n/a
The Car was tuned by GP Performance in Germany! It seems that they do their development on customer cars.
Old 07-08-2020, 07:39 AM   #20
SugarBrz
Guest
Posts: n/a
Actually I was back to a modified stock header with an 100 cell HFC from HJS but then changed due more track use to an ACE 350 Header.
Old 11-21-2020, 12:35 AM   #21
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Did you have any issue with stock header with stock cat?
Thanks
botbs is offline   Reply With Quote
My 2013 Subaru BRZ Turbo build Suparu Member's Car Journals 38 07-08-2020 06:25 PM
Will300's Subaru BRZ Build (UK) will300 Member's Car Journals 52 04-15-2020 09:24 AM
Subaru BRZ Build opinions MyZC6 Scion FR-S / Toyota 86 GT86 General Forum 28 08-16-2017 04:52 PM
Build thread. Subaru BRZ #ProjectNightmare zenex Forced Induction 23 10-09-2016 12:09 AM
My 2015 Subaru brz N/A build bilsteinmotorsport K Member's Car Journals 6 06-10-2015 08:31 PM
