Old 06-07-2015, 06:11 PM   #1
bilsteinmotorsport K
Drives: Subaru Brz 2015 manual
My 2015 Subaru brz N/A build
Hello , would like to share my build here with some pictures showing up my mod on the brz ...
first few weeks after getting the car from the dealer , was thinking to go forced induction setup , but after reading and reading i found up that a N/A build would be a good start with the first year .
first mod was invidia d-catted test pipe , Drop in K&N filter with a custom E-tune . ends up with a great result , better throttle response and better top end .
i ended my mods so far with adding a Nameless long tube headers ,perrin intake pipe, tomei overpipe and Greddy SP supreme catback . yes you can call it Frankenstein lol . will post some dyno results .
the car now is pulling so hard and crazy sound as well . cruising sound is awesome because Greddy sp supreme catback .
MOD LIST
Interior :
ATI Vent Pod 60mm
Innovate MTX AFR
Beatrush Duracon Shift Knob Black
JPM Coachworks OEM Cluster Hood Black Alcantara Red Stitching
Cusco Spin Turn Knob Red
Exterior :
ROWEN front lip
ROWEN rear under spoiler with quad tips
quad tips stainless steel (oem STI tips)
Suspension :
Bilstein PSS10 coilovers
Whiteline Differential Mount Cradle Insert Bushing
Whiteline Steering Rack and Pinion Mount Bushings
Whiteline Rear Positive Traction Kit Inserts
Whiteline Front Lower Control Arm Bushing Rear
Cusco Front Strut Tower Bar Type OS
Whiteline Front Roll Center Adjustment Kit
Perrin PSRS Offset Bushings
Drivetrain and transmission :
Whiteline Gearbox Positive Shift Kit
Perrin Transmission Mount Support
Kartboy Rear Shifter Bushing
Cusco Engine Mount Set
Wheels :
RAYS 57extreme 18x7.5 offset+40 all around
RAYS lug nuts blue
Engine and performance :
invidia test pipe D-catted
Tomei over pipe
Nameless Long tube headers
Greddy SP supreme catback (edited 4 tips)
K&N drop in filter
Kartboy Aluminum Crank Pulley
Perrin 3inch intake pipe
Custom E-TUNE
More to do on the car so soon ... will keep posting what's new . cheers
cheers
bilsteinmotorsport K is offline   Reply With Quote
Old 06-07-2015, 06:15 PM   #2
Old 06-08-2015, 09:48 PM   #3
airjonny
airjonny's Avatar
Drives: Nissan Murano
Yes. Moar N/A builds!
airjonny is offline   Reply With Quote
Old 06-08-2015, 10:33 PM   #4
celek
Resident Gear Head
celek's Avatar
Great to have another NA fanatic on the board!
I am now 1 year 4 months into my custom block too slow
celek is offline   Reply With Quote
Old 06-09-2015, 01:58 AM   #5
Slammedsteve
Drives: 2013 Asphalt Fr-s,91 240sx missle
Rear shot looks great, where's the rest tho?
Slammedsteve is offline   Reply With Quote
Old 06-09-2015, 06:17 PM   #6
Old 06-10-2015, 08:31 PM   #7
Slammedsteve
That's better! Cars lookin good bro, you should get a vinyl for the tail lights or just some new tail lights.
SON1C v3 -> 2015 Subaru BRZ Series Blue Build SON1C Member's Car Journals 15 06-26-2016 12:13 PM
My 2015 Halo FR-S Build DimSumHero Member's Car Journals 4 05-29-2016 02:03 AM
Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** RallySport Direct Transmission and Driveline 59 09-01-2015 12:18 PM
hasanaltan's FR-S Build (2015 Asphalt 6MT) hasanaltan Member's Car Journals 8 08-06-2015 12:57 PM
