Old 11-06-2019, 02:25 PM   #15
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
If they didn't disconnect the battery before pulling the whole engine out,
I'd have some very scatological invective to share with them.
Ultramaroon (11-07-2019)
Old 11-06-2019, 03:34 PM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by jc7993 View Post
Haha no I was told not to hammer it for the first thousand miles so I kept it under 4k rpm. It's been hard not to....
They told you not to hammer it because after 1,000 miles if the engine blows it's harder to pin the blame on them.
The Following User Says Thank You to DarkPira7e For This Useful Post:
davesrave (11-06-2019)
Old 11-06-2019, 05:38 PM   #17
jc7993
Drives: Looking to buy
What the... Is that true?
jc7993 is offline   Reply With Quote
Old 11-06-2019, 05:52 PM   #18
gravitylover
It shouldn't be. There is a 12mo/12k mile warranty on the work. The dealer that did mine actually told me to go out and drive it hard after the first few days.
Old 11-06-2019, 07:13 PM   #19
DarkPira7e
DarkPira7e's Avatar
Forgive me if I'm a bit jaded probably not the whole truth
Old 11-06-2019, 07:35 PM   #20
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
After more than a thousand miles, my mileage is down maybe .5 MPG. I did get a map update out of it, though nothing was ever mentioned about this. Wonder if other things were done such as an ECU update?
davesrave is offline   Reply With Quote
Old 11-06-2019, 07:52 PM   #21
jc7993
Should I try to reflash my tune? I am using an OFT tuner
Old 11-06-2019, 07:54 PM   #22
davesrave
davesrave's Avatar
Why not. What do you have to lose?
Old 11-06-2019, 08:11 PM   #23
.5? That is well within the difference expected with cold weather. There is nothing wrong with your car. You don't need to change to tune. It isn't beyond what would be expected and will go back to "normal" when it warms up outside.
ls1ac (11-06-2019)
Old 11-06-2019, 08:24 PM   #24
davesrave
davesrave's Avatar
No, I get it. I was talking about the satellite map getting a free update, and then wondering if anything else got updated. I'm fine with the outcome so far.
The Following User Says Thank You to davesrave For This Useful Post:
Tcoat (11-06-2019)
Old 11-06-2019, 08:27 PM   #25
The map is a whole different thing than the ECU. No cross over. There were probably at least a couple of head unit updates they had to do. They just can't seem to master those.
Old 11-06-2019, 08:54 PM   #26
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'm basically the same before and after.
Old 11-06-2019, 09:32 PM   #27
humfrz
Going by the computer average mpg. I usually keep my eye on the fluctuating mpg while I'm driving and I noticed this change. It has been about 300miles since I got it back.
I suggest you check your fuel mileage the old fashioned way - with a pencil and a piece of paper. Check at least 3 tanks full.
Sometimes, those electronic things lie -
humfrz
Old 11-06-2019, 09:38 PM   #28
davesrave
davesrave's Avatar
humfrz
I check it both ways and find the car calculated MPG is very accurate. That is, assuming that the car calculates correct mileage, which is sketchy, because GPS MPH readings are always lower by 1 or 2 MPH than what the digital speedometer says it is. So, even if your using pencil and paper, you're still relying on the mileage that the car calculates which may or may not be accurate.
The Following 2 Users Say Thank You to davesrave For This Useful Post:
humfrz (11-06-2019), jc7993 (11-07-2019)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Not doing the Valve Spring Recall? arnie0000 Issues | Warranty | Recalls / TSB 30 08-06-2019 06:24 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
