#15 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If they didn't disconnect the battery before pulling the whole engine out,
I'd have some very scatological invective to share with them.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Ultramaroon (11-07-2019) |
#16 |
Rust bucket enthusiast
They told you not to hammer it because after 1,000 miles if the engine blows it's harder to pin the blame on them.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | davesrave (11-06-2019) |
#17 |
Drives: Looking to buy
#18 |
It shouldn't be. There is a 12mo/12k mile warranty on the work. The dealer that did mine actually told me to go out and drive it hard after the first few days.
#19 |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Ultramaroon (11-07-2019) |
#20 |
Drives: 2014 Boxster S; 2015 Macan S
After more than a thousand miles, my mileage is down maybe .5 MPG. I did get a map update out of it, though nothing was ever mentioned about this. Wonder if other things were done such as an ECU update?
#21 | |
Sent from my GM1915 using Tapatalk |
#22 |
#23 |
.5? That is well within the difference expected with cold weather. There is nothing wrong with your car. You don't need to change to tune. It isn't beyond what would be expected and will go back to "normal" when it warms up outside.
| The Following User Says Thank You to Tcoat For This Useful Post: | ls1ac (11-06-2019) |
#24 |
No, I get it. I was talking about the satellite map getting a free update, and then wondering if anything else got updated. I'm fine with the outcome so far.
| The Following User Says Thank You to davesrave For This Useful Post: | Tcoat (11-06-2019) |
#25 |
The map is a whole different thing than the ECU. No cross over. There were probably at least a couple of head unit updates they had to do. They just can't seem to master those.
| The Following User Says Thank You to Tcoat For This Useful Post: | davesrave (11-06-2019) |
#26 |
Dismember
Drives: 2013 Red Scion FR-S
I'm basically the same before and after.
#27 | |
Sometimes, those electronic things lie - ![]() humfrz |
#28 |
I check it both ways and find the car calculated MPG is very accurate. That is, assuming that the car calculates correct mileage, which is sketchy, because GPS MPH readings are always lower by 1 or 2 MPH than what the digital speedometer says it is. So, even if your using pencil and paper, you're still relying on the mileage that the car calculates which may or may not be accurate.
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Not doing the Valve Spring Recall? | arnie0000 | Issues | Warranty | Recalls / TSB | 30 | 08-06-2019 05:24 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
