Old 10-22-2019, 10:32 AM   #15
Leonardo
Country Boy 4 Life
Leonardo's Avatar
25mm front and 30mm rear look great! There is plenty of room.
You can run a zero offset 7" wide wheel with a few degrees of negative camber. A 17x7" ET 0 has the same poke as 18x9.5" +32.
Anyway, my point is that you will be fine with 20mm spacers in the front.
I LIKE TIRES!
Old 10-22-2019, 12:04 PM   #16
sato
sato's Avatar
Drives: Dodge Patitas
My experience was with 20mm up front and 25mm back. Those will look flush (you mentioned aesthetics). No problem with studs hitting the stock wheels. Can't say anything else since I had to remove them due to stripped nut problems on spacers.
Old 10-22-2019, 11:46 PM   #17
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by J95 View Post
I am not comfortable by grinding the studs...I could do it wrong and screw up the thread or something, I have never worked on steel
there was a point that i hadn't either. a few months ago i bought a welder. i don't have a clue what i'm doing, but you can't learn until you try!
wheel studs are really easy to replace, it's really a pretty good spot to start trying. worst case, you have to replace a few studs and start over.
Leonardo (10-23-2019)
Old 10-23-2019, 09:52 AM   #18
Leonardo
Country Boy 4 Life
Leonardo's Avatar
How I cut my studs.
First, I threaded a nut on the stud. Then measured the length. Cut the stud. Then by un-threading the nut, it repairs the thread on the end of the stud. (as long as your cut is nice) Then carefully clean up the tip of the stud with a file.
All 10 I did came out perfect.
And, like Soundman said, they are inexpensive and easy to install if you need to replace one.
I LIKE TIRES!
soundman98 (10-23-2019)
WTB: Spacers- 25mm rear, 20mm front Just Drive Canada Classifieds 1 06-26-2017 11:00 AM
FS: 4X Ichiba hubcentric 5x100 bolt on spacers front 20mm and rear 30mm for BRZ/FRS Mint86 Brakes, Suspension, Chassis 7 07-08-2015 08:05 PM
Eibach Sportline springs with 20mm front and 25mm rear spacers on stock wheels Calin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 12-12-2014 02:25 PM
*UPDATE* I got Eibach springs and spacers. Is 25mm not good enough for the rear? trinxified Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 08-22-2014 02:57 AM
