Old 10-30-2019, 09:29 AM   #15
prandelia
Drives: 2015 FRS
Originally Posted by 86MLR View Post
How do they compare in relation to m2.
Pre 17 OEM = 0.193m2
17 + OEM = 0.77m2
I acknowledge that the 17+ housings/intake tube and design are slightly larger/different but it was the filter design that was the main reason for the greater surface area.
If I recall correctly the K&N surface area is smaller than the 17+ OEM filter, the media in the K&N allows for more flow though.
Im off to google
The TRD filter size and housing is WAY longer than the '17+ cars too. Plus, there are less bends to the throttle body from the airbox.
My car sits on a trailer, so I'll have to measure it sometime this weekend.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
The Following 2 Users Say Thank You to prandelia For This Useful Post:
86MLR (10-30-2019), trvth (10-30-2019)
Old 03-06-2020, 01:39 AM   #16
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Math with oranges and apples for the win.
I couldn't help myself, I pulled my K&N for a look.
ORANGE = 2017 manual K&N airfilter (mine):
Size = 27 folds, fold height = 27mm therefore 1 fold = 54mm x 27 folds = 1.458m
Width of oiled section (not glue) = 0.1m
2017 K&N m2 = 0.145m2
So, smaller m2 than all OEM paper filters.
Assumptions:
OEM filter is paper and highly efficient at filtering, drawback is slight restriction due to this.
K&N filter is filter media is very thin and relys on oil to capture contaminates, thus less restrictive than OEM.
APPLE = TRD airfilter size?
The TRD media is a oil filter, but, is 4 ply.
Assumption: The TRD being a thicker media would be more restrictive than the K&N type.
Conclusion: could someone count the pleats and post up the dimensions of the TRD to compare against the m2 of all the other filters.
I acknowledge that the elephant in the room is the filter media, but, these comparisons are fun, and if a TRD intake filter is measurably better than a 17+ intake I might get a TRD intake.
As for the efficiency of the K&N, well it breaths effortlessly, but it only really stops rocks and leaves.
From my old eyes looking at a computer screen I counted 57 folds on that supersized TDR filter. If we assume its the same depth (27mm) then you are looking at lot of m2.
Blighty is offline   Reply With Quote
Old 03-06-2020, 02:19 AM   #17
86MLR
86MLR's Avatar
Which one?
Cotton has 15
K&N style has 34
Need dimensions of width, length and height to work out area.
Mute point as my 2017 OEM airbox with a K&N filter is not showing up as an restriction, even running a little AVO turvo.
It also wasn't showing as a restriction with the OEM paper filter when NA tuned, it did have a Mishimoto intake tube though, more to aid in a clean removal the noise tube than for performance.
For what it's worth, the TRD intake looks only slightly smaller than the OEM intake on a R33 GTR, which can flow 500hp all day.
And as the TRD intake on the twins is only ever going to flow around 200hp, I would say the size is overkill.
Yes there are variables, but in the end if there isn't a restriction, a bigger box or filter is not required.
A high flow filter in the OEM airbox is all that is required for unrestricted flow and ease of maintenance, as long as you are comfortable with the less efficient filtration of a high flow filter.
Marketing may disagree with me.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 03-06-2020, 03:31 AM   #18
Blighty
Which one?
Cotton has 15
K&N style has 34
I think you're looking at the drop in filters for the stock 13+ and 17+ models.
The one we are talking about is from the TRD Intake pictured here.
Its huge.
The Following User Says Thank You to Blighty For This Useful Post:
86MLR (03-06-2020)
Old 03-06-2020, 03:42 AM   #19
86MLR
86MLR's Avatar
Its huge.
Yeah, opps
That thing is huge
Massive bling overkill IMO
Meh, consumers will consume
Old 03-06-2020, 04:31 AM   #20
Blighty
Yeah, opps
That thing is huge
I think the OP (@prandelia) was pleased with its increase over the typical cheapo set-up after tuning, and by the looks they have built as a proper NA trackcar.
Which is no surprise really - to have almost identical maf readings with significantly less airflow resistance, should mean that not only should tuning be a little easier, but the many stock ecu maps looked-up by its built in learning software will naturally make the car more likely to avoid knocks without pulling back too much power, making the tuner changes able to go a little higher.
In theory anyway - I'm no master tuner.
But yeah its not like the value you get out of headers, which not only can give some really good top end, but have absolutely massive low/mid gains.
Old 03-06-2020, 08:02 AM   #21
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Yeah, opps
That thing is huge
Bling? It looks like a factory airbox.
I got one for a good price and it definitely cleans up the look of the engine bay and deletes all the sound tubing. It wouldn't be my first suggestion for mods, but it's one of the few intakes with a good track record and it doesn't void any warranty.
The Following User Says Thank You to Summerwolf For This Useful Post:
beltax90 (11-11-2021)
Old 03-06-2020, 09:57 AM   #22
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
How is Millers oil a variable for power? I dont see it being a variable. The only thing high quality oils do are retain viscosity, lower oil pressures/temps, and better lubrication so there is no metal on metal action. I don't see how that applies to making more power.
AutoNewb is offline   Reply With Quote
Old 03-06-2020, 10:28 AM   #23
86TOYO2k17
Drives: 2017 toyota 86
Maybe just listed as a "disclaimer" to record all the variables changing between before and after. although he never stated temperature and humidity.
But yeah it shouldn't make a difference, if anything a heavier weight oil would probably decrease HP at least until it got some temperature in it to get a good flowing viscosity.
also curious if that was K/N drop in no tune vs TRD w/ tune or both on same tune?
Regardless its obviously much larger intake/filter size so it should have the potential to flow more air, whether or not the stock NA engine can utilize that increase in airflow is another question.
Old 03-06-2020, 11:05 AM   #24
PulsarBeeerz
Drives: JRSC BRZ SOLD
He mentioned both setups were dyno tuned on the same dyno in the first post.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
86TOYO2k17 (03-06-2020)
Old 03-06-2020, 11:37 AM   #25
86TOYO2k17
Missed that parts, Thanks.
Old 03-06-2020, 11:56 AM   #26
Lantanafrs2
Drives: 2013 frs red
Good info. OP was generous to post it
Old 11-11-2021, 12:34 AM   #27
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It just changes the AFR. A proper tune can do the same w/o changing the intake box.
Old 11-13-2021, 07:10 PM   #28
jflogerzi
jflogerzi's Avatar
Yup just probably allowing the AFR to lean out just a bit... thus more HP up top.
2013 Series 10 FRS #553
JDL 4-1 dyno results CSG Mike Engine, Exhaust, Transmission 41 12-18-2019 12:05 PM
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 05:09 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 05:57 AM
K&N Intake and Unichip Dyno Results PhastekSport Engine, Exhaust, Transmission 11 04-10-2013 07:27 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
